[pgrouting-users] sew-devel-2_0 build problems
Dave Potts
dave.potts at pinan.co.uk
Sat May 25 05:53:01 PDT 2013
On 25/05/13 11:41, Daniel Kastl wrote:
> On Sat, May 25, 2013 at 6:11 PM, Dave Potts <dave.potts at pinan.co.uk
> <mailto:dave.potts at pinan.co.uk>> wrote:
> Hi list
> I want a play from the new version of the tsp code.
> I have tried building it on Ubuntu 3.2.0-43-generic #68-Ubuntu
> SMP with postgres 9.1.9 using the syntax
> cmake DebugFull .
> I got the following errors[See Below]
> Q. What should the build envronment be pgroute 2.0??
> Hi Dave,
> There seems to be a problem with the use of the Git module of CMake.
> The check for Git is not something that must be included, but it's
> convenient, because it allows to place the version information for
> example in the documentation or some time into a function to retreive
> the pgRouting version.
> I have tested, that it works when you build from a Git repository with
> Git installed.
> And I think I have tested the case when Git is not installed and it's
> not a Git repository.
> In your case, do you build from a cloned repository?
> I have already upgraded my version of cmake 2.8.11
> The required version is checked and it will give an error when your
> version is not new enough.
> These are a few commands I'm using to build on Ubuntu:
> https://gist.github.com/dkastl/5617030
Hi DAniel,
WIll check out these tools, which version off Ubuntu are you on?
I did'nt clone a copy, I just got it out as a zip file.
Dave.
> Daniel
> regards
> Dave.
> src/pgroute/pgr2.0/pgrouting-sew-devel-2_0 failed with output:
> fatal: Not a git repository (or any parent up to mount parent )
> Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM
> not set).
> Call Stack (most recent call first):
> CMakeLists.txt:68 (GIT_WC_INFO)
> CMake Warning at cmake/FindGit.cmake:144 (message):
> No remote origin set for git repository:
> /home/dp42/src/pgroute/pgr2.0/pgrouting-sew-devel-2_0
> -- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/9.1/bin/postgres
> -- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
> -- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql/9.1/server
> -- POSTGRESQL_LIBRARIES: /usr/lib
> -- Boost version: 1.48.0
> Boost headers were found here: /usr/include
> -- POSTGRESQL_VERSION_STRING is PostgreSQL 9.1.9
> -- POSTGRESQL_VERSION is 9.1.9
> -- Install directory for libraries is set to
> /usr/lib/postgresql/9.1/lib
> -- Install directory for SQL files is set to
> /usr/share/postgresql/9.1/extension
> -- LIBS_TO_INSTALL=
> -- Configuring incomplete, errors occurred!
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130525/1c67e805/attachment.html>
More information about the Pgrouting-users
