[pgrouting-users] PGRouting 2.0 for RHEL5
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Nov 25 06:39:29 PST 2013
Hi Steve,
This is a new one on me and I'm not sure what is causing that. It is not
our code directly so I would guess it is something to do with the Boot
version you have installed or with some internationalization features
related to Boost, or Postgresql, but I can't be sure.
Can you post the cmake output? That should tell use most everything.
Has anyone on the list successfully built on RHEL5??
Thanks,
-Steve
On 11/25/2013 9:19 AM, Cooling, Steve wrote:
> Hi,
> Thanks for your response. Following the manual, I did the following:
> mkdir build
> cd build
> cmake ..
> make
> sudo make install
> When running the make command I got the below errors. Any help would be greatly appreciated.
> # make
> [ 8%] Built target trsp
> [ 11%] Building CXX object src/astar/src/CMakeFiles/astar.dir/astar_boost_wrapper.cpp.o
> /usr/include/libintl.h:40: error: expected unqualified-id before âconstâ
> /usr/include/libintl.h:40: error: expected `)' before âconstâ
> /usr/include/libintl.h:40: error: expected initializer before âconstâ
> /usr/include/libintl.h:45: error: expected unqualified-id before âconstâ
> /usr/include/libintl.h:45: error: expected `)' before âconstâ
> /usr/include/libintl.h:45: error: expected initializer before âconstâ
> /usr/include/libintl.h:62: error: expected unqualified-id before âunsignedâ
> /usr/include/libintl.h:62: error: expected `)' before âunsignedâ
> /usr/include/libintl.h:62: error: expected initializer before âunsignedâ
> /usr/include/libintl.h:68: error: expected unqualified-id before âunsignedâ
> /usr/include/libintl.h:68: error: expected `)' before âunsignedâ
> /usr/include/libintl.h:68: error: expected initializer before âunsignedâ
> make[2]: *** [src/astar/src/CMakeFiles/astar.dir/astar_boost_wrapper.cpp.o] Error 1
> make[1]: *** [src/astar/src/CMakeFiles/astar.dir/all] Error 2
> make: *** [all] Error 2
> Cheers,
> Steve
> On 11/25/2013 6:43 AM, Cooling, Steve wrote:
>> Hi,
>> Is PGRouting 2.0 available as an rpm package for Redhat
>> Enterprise Linux 5.8 and has anyone managed to install it successfully?
>> I've tried compiling the source package but it has failed.
> Post how it failed and we can probably guide you through the issues.
> Is there anRHEL5 GIS package repository that someone maintains? We would
> be happy to put them on our release notification list.
> -Steve
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
