[pgrouting-users] PGRouting 2.0 for RHEL5
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Nov 25 09:51:34 PST 2013
Hi Steve,
Boost 1.33 is very old and while I have nothing to indicate that it is
not supported, that might be the problem. I have compiled 1.34 in the
past on a Debian Lenny system. Can you load a newer version of Boost?
Also, I have no idea why the perl-Boost-Graph-1.4-1.el5.rf package did
anything for you as we don't use that at all, but it may have pulled in
a needed dependency.
I'm at a loss otherwise. Maybe Devrim GÜNDÜZ has some ideas on this issue.
Thanks,
-Steve
On 11/25/2013 11:19 AM, Cooling, Steve wrote:
> Hi Steve,
> I already had boost-1.33.1-15.el5 and boost-devel-1.33.1-15.el5 installed. I've just installed the perl-Boost-Graph-1.4-1.el5.rf package and the Boost version is now showing in the cmake output - see below. Unfortunately, I'm still getting the same error when running the make.
> -- The C compiler identification is GNU 4.1.2
> -- The CXX compiler identification is GNU 4.1.2
> -- Check for working C compiler: /usr/bin/gcc
> -- Check for working C compiler: /usr/bin/gcc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- PGROUTING_G IT_TAG: pgrouting-2.0.0
> -- PGROUTING_G IT_BUILD: 0
> -- PGROUTING_G IT_HASH: f26831f
> -- PGROUTING_G IT_BRANCH: master
> -- PGROUTING_VERSION_REVISION_NAME: f26831f master
> -- PGROUTING_VERSION_REVISION_HASH: f26831f
> -- UNIX=1
> -- WIN32=
> -- POSTGRESQL_EXECUTABLE is /opt/postgres/9.1/bin/postgres
> -- POSTGRESQL_PG_CONFIG is /opt/postgres/9.1/bin/pg_config
> -- POSTGRESQL_INCLUDE_DIR: /opt/postgres/9.1/include/postgresql/server
> -- POSTGRESQL_LIBRARIES: /opt/postgres/9.1/lib
> -- Boost version: 1.33.1
> -- Boost headers were found here: /usr/include
> -- POSTGRESQL_VERSION_STRING is PostgreSQL 9.1.3
> -- POSTGRESQL_VERSION is 9.1.3
> -- PGSQL_VERSION is 91
> -- Install directory for libraries is set to /opt/postgres/9.1/lib/postgresql
> -- Contrib directory for SQL files is set to /opt/postgres/9.1/share/postgresql/contrib/pgrouting-2.0
> -- Extension directory for SQL files is set to /opt/postgres/9.1/share/postgresql/extension
> -- Found the following Boost libraries:
> -- thread
> -- CGAL_INCLUDE_DIR=/usr/local/include
> -- CGAL_LIBRARIES=/usr/local/lib/libCGAL.so
> -- BOOST_THREAD_LIBRARIES=/usr/lib64/libboost_thread.so
> -- GMP_LIBRARIES=/usr/lib64/libgmp.so
> -- Found CGAL: /usr/local/include, /usr/local/lib/libCGAL.so, /usr/lib64/libboost_thread.so, /usr/lib64/libgmp.so
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /tmp/pgrouting-2.0.0/build
> Cheers,
> Steve
> _________________________________________
> Steve Cooling
> Senior Infrastructure Engineer | Swansea ICT Services
> Capgemini UK | Swansea
> Direct Line : +44(0)1792 63 6830 | www.capgemini.com
> People matter, results count.
> -----Original Message-----
> From: pgrouting-users-bounces at lists.osgeo.org [mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
> Sent: 25 November 2013 15:40
> To: pgrouting-users at lists.osgeo.org
> Subject: Re: [pgrouting-users] PGRouting 2.0 for RHEL5
> Hi Steve,
> This is what I have from cmake on Ubuntu 12.04. You can ignore the
> messages about Sphinx and Latex. What concerns me about your build is
> that it is missing:
> -- Boost version: 1.46.1
> -- thread
> Make sure you have libboost-graph-dev and libboost-graph1 packages
> installed. These are the Ubuntu names, you probably need something like:
> sudo yum install boost-devel.x86_64 boost-graph-1.44.0-8.fc14.x86_64
> Cmake should have errored out if it failed to find the dependency, that
> might be a valid issue.
> -Steve
> -- The C compiler identification is GNU 4.6.3
> -- The CXX compiler identification is GNU 4.6.3
> -- PGROUTING_G IT_BUILD: 8
> -- PGROUTING_G IT_HASH: 92e3848
> -- PGROUTING_G IT_BRANCH: develop
> -- PGROUTING_VERSION_REVISION_NAME: 92e3848 develop
> -- PGROUTING_VERSION_REVISION_HASH: 92e3848
> -- UNIX=1
> -- WIN32=
> -- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/9.2/bin/postgres
> -- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
> -- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql/9.2/server
> -- POSTGRESQL_LIBRARIES: /usr/lib
> -- POSTGRESQL_VERSION_STRING is PostgreSQL 9.2.5
> -- POSTGRESQL_VERSION is 9.2.5
> -- PGSQL_VERSION is 92
> -- Install directory for libraries is set to /usr/lib/postgresql/9.2/lib
> /usr/share/postgresql/9.2/contrib/pgrouting-2.0
> /usr/share/postgresql/9.2/extension
> -- Checking for package 'Sphinx'
> -- Found PythonInterp: /usr/bin/python (found version "2.7.3")
> -- Could NOT find Sphinx (missing: SPHINX_EXECUTABLE SPHINX_VERSION_OK)
> CMake Warning at doc/CMakeLists.txt:17 (message):
> Sphinx not found. Cannot generate documentation!
> -- thread
> -- CGAL_INCLUDE_DIR=/usr/include
> -- CGAL_LIBRARIES=/usr/lib/libCGAL.so
> -- BOOST_THREAD_LIBRARIES=/usr/lib/libboost_thread-mt.so;pthread
> -- GMP_LIBRARIES=/usr/lib/x86_64-linux-gnu/libgmp.so
> -- Found CGAL: /usr/include, /usr/lib/libCGAL.so,
> /usr/lib/libboost_thread-mt.so;pthread, /usr/lib/x86_64-linux-gnu/libgmp.so
> -- Configuring done
> -- Generating done
> CMake Warning:
> Manually-specified variables were not used by the project:
> BUILD_LATEX
> -- Build files have been written to: /home/woodbri/work/pgrouting/build
> On 11/25/2013 10:19 AM, Cooling, Steve wrote:
>> Hi Steve,
>> Here is the cmake output.
>> -- UNIX=1
>> -- WIN32=
> missing stuff should be here:
> -- thread
>> -- Configuring done
>> -- Generating done
>> Cheers,
>> Steve
>> Steve Cooling
>> Sent: 25 November 2013 14:39
>> Hi Steve,
>> This is a new one on me and I'm not sure what is causing that. It is not
>> our code directly so I would guess it is something to do with the Boot
>> version you have installed or with some internationalization features
>> related to Boost, or Postgresql, but I can't be sure.
>> Can you post the cmake output? That should tell use most everything.
>> Has anyone on the list successfully built on RHEL5??
>> Thanks,
>> -Steve
>> On 11/25/2013 9:19 AM, Cooling, Steve wrote:
>>> Hi,
>>> Thanks for your response. Following the manual, I did the following:
>>> mkdir build
>>> cd build
>>> cmake ..
>>> make
>>> sudo make install
>>> When running the make command I got the below errors. Any help would be greatly appreciated.
>>> # make
>>> [ 8%] Built target trsp
>>> [ 11%] Building CXX object src/astar/src/CMakeFiles/astar.dir/astar_boost_wrapper.cpp.o
>>> /usr/include/libintl.h:40: error: expected unqualified-id before âconstâ
>>> /usr/include/libintl.h:40: error: expected `)' before âconstâ
>>> /usr/include/libintl.h:40: error: expected initializer before âconstâ
>>> /usr/include/libintl.h:45: error: expected unqualified-id before âconstâ
>>> /usr/include/libintl.h:45: error: expected `)' before âconstâ
>>> /usr/include/libintl.h:45: error: expected initializer before âconstâ
>>> /usr/include/libintl.h:62: error: expected unqualified-id before âunsignedâ
>>> /usr/include/libintl.h:62: error: expected `)' before âunsignedâ
>>> /usr/include/libintl.h:62: error: expected initializer before âunsignedâ
>>> /usr/include/libintl.h:68: error: expected unqualified-id before âunsignedâ
>>> /usr/include/libintl.h:68: error: expected `)' before âunsignedâ
>>> /usr/include/libintl.h:68: error: expected initializer before âunsignedâ
>>> make[2]: *** [src/astar/src/CMakeFiles/astar.dir/astar_boost_wrapper.cpp.o] Error 1
>>> make[1]: *** [src/astar/src/CMakeFiles/astar.dir/all] Error 2
>>> make: *** [all] Error 2
>>> Cheers,
>>> Steve
>>> On 11/25/2013 6:43 AM, Cooling, Steve wrote:
>>>> Hi,
>>>> Is PGRouting 2.0 available as an rpm package for Redhat
>>>> Enterprise Linux 5.8 and has anyone managed to install it successfully?
>>>> I've tried compiling the source package but it has failed.
>>> Post how it failed and we can probably guide you through the issues.
>>> Is there anRHEL5 GIS package repository that someone maintains? We would
>>> be happy to put them on our release notification list.
>>> -Steve
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
