[pgrouting-users] Aaargh! Building is hard... .
Worth Lutz
wal3 at mindspring.com
Wed Nov 27 08:42:32 PST 2013
I've had not problems installing pgRouting on Ubuntu 12.04 using the
packages. Lucky? :-)
Worth Lutz
_____
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Stephen Mather
Sent: Wednesday, November 27, 2013 11:33 AM
To: pgRouting Users List
Subject: Re: [pgrouting-users] Aaargh! Building is hard... .
BTW, interesting artifact of (I think) all the machinations to build
pgRouting-- now the package manager version works... . I'm wondering if the
package manager was build on a clean build of Ubuntu, or one which may have
had custom built libraries (just making wild guesses here...).
Thanks,
Best,
Steve
On Wed, Nov 27, 2013 at 11:21 AM, Stephen Mather <stephen at smathermather.com>
wrote:
Hi All,
The package management for Ubuntu 12.04 isn't working for me (see earlier
message about this), so I decided I'm an adequate keyboard cowboy to build
from source, but alas, no such luck.
steve at lion:~/Documents/github/pgrouting$ mkdir build
steve at lion:~/Documents/github/pgrouting$ cd build/
steve at lion:~/Documents/github/pgrouting/build$ cmake -DWITH_DD=ON ..
-- The C compiler identification is GNU 4.6.3
-- The CXX compiler identification is GNU 4.6.3
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- PGROUTING_GIT_TAG: pgrouting-2.0.0
-- PGROUTING_GIT_BUILD: 0
-- PGROUTING_GIT_HASH: d6ed2cb
-- PGROUTING_GIT_BRANCH: master
-- PGROUTING_VERSION_REVISION_NAME: d6ed2cb master
-- PGROUTING_VERSION_REVISION_HASH: d6ed2cb
-- UNIX=1
-- WIN32=
-- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/9.1/bin/postgres
-- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
-- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql/9.3/server
-- POSTGRESQL_LIBRARIES: /usr/lib
-- Boost version: 1.55.0
-- Boost headers were found here: /usr/local/include
-- POSTGRESQL_VERSION_STRING is PostgreSQL 9.3.1
-- POSTGRESQL_VERSION is 9.3.1
-- PGSQL_VERSION is 93
-- Install directory for libraries is set to /usr/lib/postgresql/9.3/lib
-- Contrib directory for SQL files is set to
/usr/share/postgresql/9.3/contrib/pgrouting-2.0
-- Extension directory for SQL files is set to
/usr/share/postgresql/9.3/extension
-- Found the following Boost libraries:
-- thread
-- thread
-- system
-- CGAL_INCLUDE_DIR=/usr/local/include
-- CGAL_LIBRARIES=/usr/local/lib/libCGAL.so
BOOST_THREAD_LIBRARIES=/usr/local/lib/libboost_thread.so;pthread;/usr/local/
lib/libboost_thread.so;pthread;/usr/local/lib/libboost_system.so
-- GMP_LIBRARIES=/usr/lib/x86_64-linux-gnu/libgmp.so
-- Found CGAL: /usr/local/include, /usr/local/lib/libCGAL.so,
/usr/local/lib/libboost_thread.so;pthread;/usr/local/lib/libboost_thread.so;
pthread;/usr/local/lib/libboost_system.so,
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/smathermather/Documents/github/pgrouting/build
steve at lion:~/Documents/github/pgrouting/build$ make
Scanning dependencies of target trsp
[ 2%] Building C object src/trsp/src/CMakeFiles/trsp.dir/trsp.c.o
[ 5%] Building CXX object src/trsp/src/CMakeFiles/trsp.dir/trsp_core.cpp.o
[ 8%] Building CXX object
src/trsp/src/CMakeFiles/trsp.dir/GraphDefinition.cpp.o
[ 8%] Built target trsp
Scanning dependencies of target astar
[ 11%] Building C object src/astar/src/CMakeFiles/astar.dir/astar.c.o
[ 14%] Building CXX object
src/astar/src/CMakeFiles/astar.dir/astar_boost_wrapper.cpp.o
[ 14%] Built target astar
Scanning dependencies of target dijkstra
[ 17%] Building C object
src/dijkstra/src/CMakeFiles/dijkstra.dir/dijkstra.c.o
[ 20%] Building CXX object
src/dijkstra/src/CMakeFiles/dijkstra.dir/boost_wrapper.cpp.o
[ 20%] Built target dijkstra
Scanning dependencies of target kdijkstra
[ 22%] Building CXX object
src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_boost_wrapper.cpp.o
[ 25%] Building C object
src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_sp.c.o
[ 25%] Built target kdijkstra
Scanning dependencies of target apsp_johnson
[ 28%] Building C object
src/apsp_johnson/src/CMakeFiles/apsp_johnson.dir/apsp_johnson.c.o
[ 31%] Building CXX object
src/apsp_johnson/src/CMakeFiles/apsp_johnson.dir/apsp_johnson_boost_wrapper.
cpp.o
[ 31%] Built target apsp_johnson
Scanning dependencies of target apsp_warshall
[ 34%] Building C object
src/apsp_warshall/src/CMakeFiles/apsp_warshall.dir/apsp.c.o
[ 37%] Building CXX object
src/apsp_warshall/src/CMakeFiles/apsp_warshall.dir/apsp_boost_wrapper.cpp.o
[ 37%] Built target apsp_warshall
Scanning dependencies of target routing
Linking CXX shared library lib/librouting.so
[ 37%] Built target routing
Scanning dependencies of target bd_dijkstra
[ 40%] Building C object
src/bd_dijkstra/src/CMakeFiles/bd_dijkstra.dir/bdsp.c.o
[ 42%] Building CXX object
src/bd_dijkstra/src/CMakeFiles/bd_dijkstra.dir/bdsp_core.cpp.o
[ 45%] Building CXX object
src/bd_dijkstra/src/CMakeFiles/bd_dijkstra.dir/BiDirDijkstra.cpp.o
[ 45%] Built target bd_dijkstra
Scanning dependencies of target bd_astar
[ 48%] Building C object
src/bd_astar/src/CMakeFiles/bd_astar.dir/bdastar.c.o
[ 51%] Building CXX object
src/bd_astar/src/CMakeFiles/bd_astar.dir/MinHeap.cpp.o
[ 54%] Building CXX object
src/bd_astar/src/CMakeFiles/bd_astar.dir/bdastar_core.cpp.o
[ 57%] Building CXX object
src/bd_astar/src/CMakeFiles/bd_astar.dir/BiDirAStar.cpp.o
[ 57%] Built target bd_astar
Scanning dependencies of target routing_bd
Linking CXX shared library lib/librouting_bd.so
[ 57%] Built target routing_bd
Scanning dependencies of target routing_tsp
[ 60%] Building C object src/tsp/src/CMakeFiles/routing_tsp.dir/tsp2.c.o
[ 62%] Building C object src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.o
Linking C shared library ../../../lib/librouting_tsp.so
[ 62%] Built target routing_tsp
Scanning dependencies of target routing_ksp
[ 65%] Building CXX object
src/ksp/src/CMakeFiles/routing_ksp.dir/BaseGraph.cpp.o
[ 68%] Building CXX object
src/ksp/src/CMakeFiles/routing_ksp.dir/BasePath.cpp.o
[ 71%] Building CXX object
src/ksp/src/CMakeFiles/routing_ksp.dir/DijkstraShortestPathAlg.cpp.o
[ 74%] Building CXX object
src/ksp/src/CMakeFiles/routing_ksp.dir/Graph.cpp.o
[ 77%] Building CXX object
src/ksp/src/CMakeFiles/routing_ksp.dir/HeaderTest.cpp.o
[ 80%] Building CXX object
src/ksp/src/CMakeFiles/routing_ksp.dir/YenTopKShortestPathsAlg.cpp.o
[ 82%] Building C object src/ksp/src/CMakeFiles/routing_ksp.dir/ksp.c.o
[ 85%] Building CXX object
src/ksp/src/CMakeFiles/routing_ksp.dir/KSPDriver.cpp.o
[ 88%] Building CXX object
src/ksp/src/CMakeFiles/routing_ksp.dir/KSPGraph.cpp.o
Linking CXX shared library ../../../lib/librouting_ksp.so
[ 88%] Built target routing_ksp
Scanning dependencies of target routing_dd
[ 91%] Building C object
src/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.c.o
[ 94%] Building CXX object
src/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.cpp.o
[ 97%] Building CXX object
src/driving_distance/src/CMakeFiles/routing_dd.dir/boost_drivedist.cpp.o
[100%] Building C object
src/driving_distance/src/CMakeFiles/routing_dd.dir/drivedist.c.o
Linking CXX shared library ../../../lib/librouting_dd.so
[100%] Built target routing_dd
steve at lion:~/Documents/github/pgrouting/build$ sudo make install
Install the project...
-- Install configuration: ""
-- Installing: /usr/lib/postgresql/9.3/lib/librouting_bd.so
-- Installing: /usr/lib/postgresql/9.3/lib/librouting.so
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting--2.0.0.sql
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting.control
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting_legacy.sql
-- Installing: /usr/share/postgresql/9.3/contrib/pgrouting-2.0/pgrouting.sql
-- Installing:
/usr/share/postgresql/9.3/contrib/pgrouting-2.0/pgrouting.control
-- Installing:
/usr/share/postgresql/9.3/contrib/pgrouting-2.0/pgrouting_legacy.sql
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting_dd_legacy.sql
-- Installing:
/usr/share/postgresql/9.3/contrib/pgrouting-2.0/pgrouting_dd_legacy.sql
-- Installing: /usr/lib/postgresql/9.3/lib/librouting_tsp.so
-- Installing: /usr/lib/postgresql/9.3/lib/librouting_ksp.so
-- Installing: /usr/lib/postgresql/9.3/lib/librouting_dd.so
-- Removed runtime path from "/usr/lib/postgresql/9.3/lib/librouting_dd.so"
Now I create extension:
CREATE EXTENSION pgrouting;
And get the following error (naturally, since librouting_dd is being removed
here at the end...):
ERROR: could not load library
"/usr/lib/postgresql/9.3/lib/librouting_dd.so": libCGAL.so.10: cannot open
shared object file: No such file or directory
********** Error **********
SQL state: 58P01
Any idea what I'm doing wrong?
Best
Steve
_____
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2014.0.4259 / Virus Database: 3629/6871 - Release Date: 11/27/13
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20131127/dfe5732d/attachment.html>
More information about the Pgrouting-users
