[pgrouting-users] pgr_createTopology
Stephen Mather stephen at smathermather.com
Sat Nov 30 13:43:41 PST 2013
Done.  Issue #220 <https://github.com/pgRouting/pgrouting/issues/220>.
Thanks,
Best,
Steve
On Sat, Nov 30, 2013 at 2:52 PM, Stephen Mather
<stephen at smathermather.com>wrote:
> Cool, I'll write a ticket.  It would be mostly useful in the case of e.g.
> tutorial development.
> Best,
> Steve
> On Sat, Nov 30, 2013 at 2:46 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> On 11/30/2013 2:18 PM, Stephen Mather wrote:
>>> Is pgr_createTopology deterministic in how it numbers nodes in a built
>>> topology?
>> Stephen,
>> What do you mean by this?
>> If you build a topology on the same edge table twice, do we guarantee
>> that the nodes numbers will be identical?
>> I think the answer is NO, on line:303 of src/common/sql/pgrouting_topology.sql
>> there is no "order by" clause. This would need to be added to make it
>> deterministic because relational set theory does not guarantee order of
>> records in a query without explicitly including and "order by" clause.
>> Write a bug if you think this is needed and state why.
>> Thanks,
>>   -Steve
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20131130/d71c1d87/attachment.html>
More information about the Pgrouting-users mailing list
