[pgrouting-users] Subject: Re: [postgis-users] k-shortst paths
Stephen Woodbridge woodbri at swoodbridge.com
Wed Sep 25 07:27:50 PDT 2013
Please post this on the pgrouting list so others can learn from your
experience.
What do the follow queries report?
select * from pgr_version();
select version();
Try changing the query to:
select ksp.id1, ksp.id3, n.source, n.target,
  round(st_length(n.the_geom)::numeric, 2) as len
     from pgr_ksp(
       'select source, target, cost,reverse_cost, id from network order
by id'::text,
       4,
       5,
       15,
       'f'::boolean) ksp,
           network n
    where ksp.id3=n.id
    order by ksp.id1, ksp.id3;
By the way this function is part of pgRouting 2.0 and will not work on
version 1.x
-Steve
On 9/25/2013 8:54 AM, Tina Musa wrote:
> Hello Steve,
> thank you for the help
> I loaded data file, it is ok.
> I saw the test file, i run the sql query
> -- Generate 15 shortest paths between nodes 4 and 5
> -- List by links
>    from pgr_ksp(
>      'select source, target, cost,reverse_cost, id from network order by
> id',
>      4,
>      5,
>      15,
>      'f') ksp,
>          network n
>   where ksp.id3=n.id
> But it the function pgr_ksp doesn't existed
> Who can be the problem?
> ERROR: function pgr_ksp(unknown, integer, integer, integer, unknown)
> does not exist LINE 2: from pgr_ksp( ^ HINT: No function matches the
> given name and argument types. You might need to add explicit type
> casts. ********** Error ********** ERROR: function pgr_ksp(unknown,
> integer, integer, integer, unknown) does not exist SQL state: 42883
> Hint: No function matches the given name and argument types. You might
> need to add explicit type casts. Character: 77
> Message: 10
> Date: Mon, 23 Sep 2013 09:25:49 -0400
> From: Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
> To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> Message-ID: <5240415D.2080608 at swoodbridge.com
> <mailto:5240415D.2080608 at swoodbridge.com>>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Tina,
> you should be asking this question on the Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> If you look in github
> https://github.com/pgRouting/pgrouting/tree/master/src/ksp/test
> there are tests for all the code, load the *.data file, then look at the
> *.test files and you can run them.
> Docs are here
> http://docs.pgrouting.org/
> See you on the other list.
> -Steve
> On 9/23/2013 8:57 AM, Tina Musa wrote:
>> Hello,
>> I see in pg routing web site that provide Yen algorithm function.
>> I try to run the algorithm but it's impossible to do.
>> Can you tell me the steps that i can do to run the algorithm successfully?
>> Thank you in advance
More information about the Pgrouting-users mailing list
