[pgrouting-users] How to merge GPS traces which are close to each other
Raghavan Krishnasamylakshmanaperumal rkrish20 at uic.edu
Tue Apr 8 20:14:45 PDT 2014
Thanks for the response. Sure I will check if openstreetmap or GRASS GIS
and keep posted if I can solve this issue.
Thanks,
Raghavan
On Wed, Apr 2, 2014 at 2:39 PM, Stephen Mather <stephen at smathermather.com>wrote:
> The openstreetmap community has also done some good practical work in this
> domain.
> Best,
> Steve
> On Apr 2, 2014 1:09 PM, "Stephen Woodbridge" <woodbri at swoodbridge.com>
> wrote:
>> On 4/2/2014 12:16 PM, Raghavan Krishnasamylakshmanaperumal wrote:
>>> Hello Everyone,
>>> I have raw GPS points collected from runkeeper(runner/biker) traces.
>>>  From these points I am creating linestrings and on linestrings I am
>>> applying pgr_nodeNetwork to create the network edge table and then
>>>   using pgr_createTopology to build the topology with source and target
>>> information.
>>> How can I merge the gps traces which are close to each other, for
>>> example look at the picture which I have attached in which there are 3
>>> GPS traces(red,green,blue) which are close to each  and while forming
>>> the network graph I want these traces to be considered as a single
>>> trace(as shown in black color). It will be better to get the average of
>>> those 3 GPS traces to form a single GPS trace by this way I may get rid
>>> of the noise on the GPS traces obtained from runkeeper.
>>> Is there a function in pgRouting to make this possible?
>> No pgRouting does not have a function for this. While it would be useful,
>> I think it falls more under PostGIS because this is a geometry problem.
>> I will also note that the problem is not well defined. Consider the case
>> where you have an exit ramp the parallels the highway for some time before
>> connecting to a cross road or veering away from the highway. In this case
>> how does one determine where to make the intersection of the ramp and
>> highway?
>> Ask the PostGIS list for some ideas. You might also ask GRASS GIS list
>> they might have some tools for this.
>> -Steve
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Thanks and Regards,
Raghavan KL
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140408/718f1c09/attachment.html>
More information about the Pgrouting-users mailing list
