[pgrouting-users] Reg: Introduction to VRP Pickup and Delivery problem and work done in GSoC
Julien-Samuel Lacroix
jlacroix at mapgears.com
Tue Aug 26 08:44:36 PDT 2014
Congratulation!
I would be interested in learning more about this new feature. Can you
give us details on the inputs?
What is the schema of the customer table?
What are the 2 other arguments in the function?
Can you briefly describe a simple real life use case that is represented
by your example?
Thank you,
Julien
On 14-08-26 02:09 AM, Manikanta Kondeti wrote:
> Hi all,
> I am Manikanta, a GSoC student for pgRouting. I've implemented a
> partially optimized VRP-Pickup and Delivery Problem with time windows.
> This algorithm has many practical uses in the real world. There is a big
> scope to extend this problem and implement further.
> I thank my mentors Daniel and Steve for giving me this wonderful
> opportunity and guiding me in the right way. Solving routing problems
> became my passion and interest. Hence I'd love to contribute to
> pgRouting in the future as well. This GSoC will be the first step. A lot
> more to come.
> *Repo details:*
> https://github.com/pgRouting/pgrouting/tree/gsoc-vrppdtw/src/vrppdtw/src
> *How to test it:*
> * Clone it from github
> * Compile and build it
> mkdir build && cd build
> cmake -DWITH_DD=ON ..
> make
> sudo make install
> * Open psql command line (sudo su postgres)
> \c pgr_test__db__test (Select Database)
> select * from pgr_gsoc_vrppdtw('select * from
> customer'::text, 25, 200);
> * Output:*
> **Output has 4 columns(seq, rid, nid, cost)
> seq: starts from 0(first route first node) to (last route
> last node)
> rid: Shows the route id
> nid: Nodes in that particular route
> cost: Cost calculated till that point
> Example: /Sample output /
> 0 | 1 | 0 | 0
> 1 | 1 | 79 | 668
> 2 | 1 | 80 | 859
> 3 | 1 | 49 | 1091
> 4 | 1 | 47 | 1183
> 5 | 1 | 0 | 1201
> 6 | 2 | 0 | 0
> 7 | 2 | 81 | 47
> 8 | 2 | 76 | 293
> 9 | 2 | 70 | 477
> 10 | 2 | 73 | 570
> 11 | 2 | 0 | 625
> / Interpretation of this will be/:
> From seq 0 to 5 has details about first route and seq 6 to 11
> about second route.
> _Route 1_: Nodes->[0 79 80 49 47 0] Cost -> [0 658 859 1091 1183 1201]
> _Route 2:_ Nodes->[0 81 76 70 73 0] Cost -> [0 47 293 477 570 625]
> So final costs for route1 and route2 are 1201 and 625.
> I'm planning to write a blog which contains all of these details. I'll
> do it in a few weeks. Before that if you find any difficulties or want
> to give me suggestions, feel free to contact me. Hope everything goes well.
> Finally this is one of my best summers, thanks to my mentors & pgRouting
> community. You're awesome :)
> Thanks
> Manikanta
> LSI, IIIT-H
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
T: +1 418-696-5056 #202
Mapgears
http://www.mapgears.com/
More information about the Pgrouting-users
