[pgrouting-users] Shortest path with edge-parameters affecting the whole path
Nicklas Avén
nicklas.aven at jordogskog.no
Sat Dec 13 12:05:56 PST 2014
Hallo list
I have a question that I don't know if it is a question worth a
rtfm-answer or if it needs hacking the source to solve. I have tried to
find any obvious answers but failed.
The problem is in my case connected to transportation of timber. All
roads have a classification of maximum aloud weight of the truck (or per
axle to be more accurate). The result is that the cost (in money) for a
transport is defined by the worst part of the path because that limits
how much timber the truck can take. That might be just a bridge or a
part of the road that is too weak to take a full loaded truck, which
gives a higher price for the whole transport.
This classification is a property of the edges. So the shortest path
algorithms needs to carry the classification information about the, so
far worst road part, as a parameter in the cost calculations.
Is there any feature in pgrouting handling this?
I have read some about Dijkstra and as far as I understand it should be
quite straight forward to handle. What is needed is that not only the
cost is stored for each resulting vertexes but also the worst
classification to get to that vertex. Then that classification is
inherited along the path until an even worse classification is found.
So, first: Is something like this already implemented?
Second, if not; Does the idea about how it could be solved make sense?
Thanks
Nicklas Avén
More information about the Pgrouting-users
