[pgrouting-users] pgrouting Dijksta Travelling Salesman Problem (TSP) with OpenStreetmap
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Feb 20 06:41:13 PST 2014
Hi Carsten,
The functions at
http://dose.0wnz.at/scripts/sql/pgroute_tspDijkstra.sql
are not part of pgRouting.
You need to ask this question to Ivan the author of the original article.
You probably need to add some debug statements to get a better
understanding of what the code is doing. For example in
pgr_makeDijkstraMatrix before the statement:
ids := ids || array[r2.id1];
Add:
raise notice 'r2: %', r2;
raise notice 'r2.id1: %', r2.id1;
raise notice 'ids: %', ids;
This should show you the progression of how the array ids is getting
built as it appears to be compaining about that in the error message.
Hope this helps,
-Steve
On 2/20/2014 9:21 AM, Carsten Hogertz wrote:
> Hi everybody, I am new to this list and new to pgrouting.
> I found the following TSP example
> http://hardwarefetish.com/513-pgrouting-dijksta-travelling-salesman-problem-tsp-with-openstreetmap
> and tried to reproduce the solution.
> Unfortunately I always get an error message.
> My DB is complaining about one of your functions.
> I got my routing table from osm2po. The table has the following structure:
> 1;”id”;”integer”
> 2;”osm_id”;”bigint”
> 3;”osm_name”;”character varying”
> 4;”osm_meta”;”character varying”
> 5;”osm_source_id”;”bigint”
> 6;”osm_target_id”;”bigint”;
> 7;”clazz”;”integer”
> 8;”flags”;”integer”
> 9;”source”;”integer”
> 10;”target”;”integer”
> 11;”length”;”double precision”
> 12;”kmh”;”integer”
> 13;”cost”;”double precision”
> 14;”reverse_cost”;”double precision”
> 15;”x1″;”double precision”
> 16;”y1″;”double precision”
> 17;”x2″;”double precision”
> 18;”y2″;”double precision”
> 19;”geom_way”;”geometry(LineString,4326)”
> - I installed the functions as mentioned via SQL window in pgAdmin3
> (copy&paste then excecute)
> - I create and populate the my_route table
> - When it comes to step 5 and I try
> select id,lon,lat from pgr_tspDijkstraLen(’my_route’, 1260
> ) dj, my_route rt where dj.id2=rt.node;
> my DB warns
> ERROR: cannot concatenate incompatible arrays
> DETAIL: Arrays with differing element dimensions are not compatible for
> concatenation.
> CONTEXT: PL/pgSQL function “pgr_makedijkstramatrix” line 25 at
> assignment PL/pgSQL function “pgr_tspdijkstra” line 8 at RETURN QUERY
> PL/pgSQL function “pgr_tspdijkstralen” line 3 at RETURN QUERY
> ********** Fehler **********
> ERROR: cannot concatenate incompatible arrays SQL Status:2202E
> Detail:Arrays with differing element dimensions are not compatible for
> concatenation.
> Kontext:PL/pgSQL function “pgr_makedijkstramatrix” line 25 at assignment
> Do you have any idea what went wrong? I really really need your
> solutionget working. I would appreciate a lot.
> Thanks for your help.
> PS: this text is a copy of what I wrote on on the comment site of the
> blog where I found the solution.
> BR
> Carsten
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
