[pgrouting-users] pgrouting Dijksta Travelling Salesman Problem (TSP) with OpenStreetmap
Carsten Hogertz
carsten.hogertz at gmail.com
Tue Feb 25 12:14:58 PST 2014
Hi Steve,
have been busy the last days so I only check your Thursday's solution right
now. Still not working.
My function looks like this:
create or replace function pgr_makeDijkstraMatrix(thetbl text, sqlP text,
OUT dmatrix double precision[], OUT ids integer[])
as
$body$
declare
sql text;
sql2 text;
r record;
r2 record;
i integer;
j integer;
matrixl double precision[];
begin
ids := '{}'::integer[];
sql:='select node, id-1 as id from '||thetbl;
for r in execute sql loop
sql2:='select id1, array_agg(cost) as arow from (
SELECT id1, id2, cost
FROM pgr_kdijkstraCost('''||sqlP||''', '||r.node||
', (select array_agg(node) from '||thetbl||' where
id>'||r.id||'),
false, false)
) as foo group by id1 order by id1';
for r2 in execute sql2 loop
matrixl := '{}';
for i in 1..r.id loop
matrixl := array_append(matrixl, dmatrix[i][r.id+1]);
end loop;
matrixl := array_cat(matrixl, r2.arow);
dmatrix := array_cat(dmatrix, array[matrixl]);
raise notice 'r2: %', r2;
raise notice 'r2.id1: %', r2.id1;
raise notice 'ids: %', ids;
--ids := ids || r2.id1;
ids := array_cat(ids, array[r2.id1]);
end loop;
end loop;
end;
$body$
language plpgsql stable cost 10;
create or replace function pgr_tspDijkstra(thetbl text, sql text, start_id
integer, end_id integer default (-1))
returns setof pgr_costResult as
$body$
declare
sid integer;
eid integer;
begin
return query with dm as (
select * from pgr_makeDijkstraMatrix( thetbl, sql )
ids as (
select (row_number() over (order by id asc))-1 as rnum, id
from (
select unnest(ids) as id
from dm
) foo
t as (
select a.seq, b.rnum, b.id
from pgr_tsp(
(select dmatrix from dm),
(select rnum from ids where id=start_id limit
1)::integer,
(case when end_id = -1 then -1 else (select rnum from
ids where id=end_id limit 1) end)::integer
) a,
ids b
where a.id=b.rnum
r as (
select array_agg(t.rnum) as rnum from t
select t.seq::integer,
t.rnum::integer as id1,
t.id::integer as id2,
dm.dmatrix[r.rnum[t.seq+1]+1][r.rnum[(t.seq+1)%array_length(r.rnum,
1)+1]+1]::float8 as cost
from t, dm, r;
end;
$body$
language plpgsql volatile cost 50 rows 50;
create or replace function pgr_tspDijkstraLen(thetbl text, start_id
$body$
begin
return query SELECT * FROM pgr_tspDijkstra(thetbl,
'SELECT id, source::integer, target::integer, length::double
precision AS cost FROM cgn_2po_4pgr',
start_id, end_id);
end;
$body$
language plpgsql stable;
AND the error I am getting:
NOTICE: r2:
(34304,"{0,5.3602868897,4.6782573327,5.6026971537,5.2062747797,5.0497181017,5.3147719797,5.0700916462,4.3220066797,4.8593618137,4.0002255227,6.055760592,12.5155379824,9.3170226155,8.72783427270001,5.9460446587,3.0868131677,5.1839796057,5.2301666167,2.1211198847,5.7037465591,2.7282842677,8.4758437557,11.1027935904,7.9434273599,7.8361619299,7.7610621969,7.4929139614,5.8106133327,5.9579132527,5.9888473034,6.5618433959,4.5013708887,1.9218516244,5.7559805232,5.2267081177,5.0968196707,4.8949133597,5.9137964962,4.2936059427,4.6948533593,3.4377318427,3.7991617067,4.1242444467,3.8858731777,3.9596393887,4.9192685996,4.6734033563,4.7511846457,4.4544981945,4.2748693367,3.411559417,6.6851381985,6.6744741285,6.9296475385,7.0136847108,7.1371500908,7.2719520708,6.6787720528,7.3530295908,6.8599596928,7.2216891568,7.4951304208,7.4404728868,8.1332243958,6.2736028029,6.963685048,6.0483763169,5.8653351624,5.6164044005,6.54979166,5.8783224469,6.533468297,5.8553434082,5.7676662122,6.267915357,5.2260793903,3.745459072,6.352470342,5.4392033722,5.5562602522,5.3996670482,6.171297855,5.648779598,5.5653279855,5.671668653,5.3243595462,5.879320328,5.859442385,6.080574272,5.3767159992,6.170852717,5.3001119472,5.687201287,5.3573110752,3.586385579,5.566591422,5.5104826925,5.916268775,5.4418422465,5.4037394705,5.640889612,5.1407657702,4.5523677017,5.3873769863,3.601570449,2.978252449,4.8725960282,4.9817842222,5.2355359365,5.1227105795,5.177856607,5.098596533,5.1891181988,4.9327118245,4.4632330777,7.4879538737,4.8591269625,3.1339054377,5.8472818275,4.6043306952,3.3542942377,4.7660145915,6.6679095357,5.51150886,2.7404344677,5.9332075344,6.2019594857,5.266709364,5.4924174224,5.180577724,3.0277711677,6.2913260157,4.2862670877,5.5461328154,5.5809644644,5.1132029296,5.1904326724,4.8352505633,4.9641930171,5.1366240426,7.0699378037,3.1274712477,5.1487646306,5.2717034197,5.0200090866,3.0911490977,5.8984613527,5.1973381747,4.2427530627,6.7293864957,4.7943011637,5.1130266607,5.3948779287,4.7124246547,5.2186371577,2.9723417287,2.3171875277,2.8159853427,4.7913513947,4.7863347867,3.4531342837,3.8161332287,5.8431115757,4.4873126817,5.6577494097,5.5867970832,9.4583860946,2.7784615917,5.4279953797,1.9376872717,5.0813930177,5.8860618114,6.2411339874,6.4536904614,6.0972641874,5.7247963284,5.9823452114,5.8316140784,5.2398164977,6.2963392357,5.5864457124,6.1599995178,5.2609646384,6.1012355027,6.4129483756,6.0056487896,5.0106569884,5.4239402364,6.1148656496,2.673828844,4.3332873457,3.2943586634,4.5834393467,7.278601561,3.5870893269,3.3299191554,4.1049776549,5.9256568037,6.2719334873,6.2594329923,5.5752581689,5.6058592867,6.1311384893,6.4726413519,5.8973941434,6.2572672069,5.9667442136,5.3965422637,7.2837623985,6.9586195092,7.1137641952,6.3682104908,7.8495628418,7.2245886958,6.2983788278,7.3509762248,6.9925366658,6.5600944468,6.936328733,6.616665943,6.738732443}")
CONTEXT: PL/pgSQL function "pgr_tspdijkstra" line 8 at RETURN QUERY
PL/pgSQL function "pgr_tspdijkstralen" line 3 at RETURN QUERY
NOTICE: r2.id1: 34304
NOTICE: ids: {}
ERROR: cannot concatenate incompatible arrays
DETAIL: Arrays with differing element dimensions are not compatible for
concatenation.
CONTEXT: PL/pgSQL function "pgr_makedijkstramatrix" line 26 at assignment
********** Fehler **********
SQL Status:2202E
Detail:Arrays with differing element dimensions are not compatible for
concatenation.
Kontext:PL/pgSQL function "pgr_makedijkstramatrix" line 26 at assignment
HOW comes? I really don't know what to do.
May you be so kind and try to help again?
Thanks
Carsten
2014-02-21 9:36 GMT+01:00 Carsten Hogertz <carsten.hogertz at gmail.com>:
> 2014-02-20 23:25 GMT+01:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
> On 2/20/2014 4:59 PM, Carsten Hogertz wrote:
>>> 2014-02-20 22:47 GMT+01:00 Stephen Woodbridge <woodbri at swoodbridge.com
>>> <mailto:woodbri at swoodbridge.com>>:
>>> On 2/20/2014 4:39 PM, Carsten Hogertz wrote:
>>> 2014-02-20 22:20 GMT+01:00 Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
>>> <mailto:woodbri at swoodbridge.__com
>>> <mailto:woodbri at swoodbridge.com>>>:
>>> On 2/20/2014 3:54 PM, Carsten Hogertz wrote:
>>> Thanks Steve,
>>> coming home and adding your lines it returns with an
>>> error:
>>> NOTICE: r2:
>>> (34304,"{0,5.3602868897 <tel:3602868897>
>>> <tel:3602868897 <tel:3602868897>>,4.6782573327 <tel:6782573327>
>>> <tel:6782573327 <tel:6782573327>>,5.6026971537
>>> <tel:6026971537> <tel:6026971537 <tel:6026971537>>,5.2062747797
>>> <tel:2062747797>
>>> <tel:2062747797
>>> <tel:2062747797>>,5.__0497181017,5.3147719797 <tel:3147719797>
>>> <tel:3147719797
>>> <tel:3147719797>>,5.__0700916462,4.__3220066797,4.__8593618137
>>> <tel:8593618137>
>>> <tel:8593618137
>>> <tel:8593618137>>,4.0002255227,6.____055760592,12.5155379824
>>> <tel:5155379824>
>>> <tel:5155379824
>>> <tel:5155379824>>,9.__3170226155,8.__
>>> 72783427270001,5.__9460446587,__3.0868131677,5.__1839796057,
>>> 5.__2301666167,2.__1211198847,5.__7037465591
>>> <tel:7037465591>
>>> <tel:7037465591
>>> <tel:7037465591>>,2.__7282842677,8.4758437557 <tel:4758437557>
>>> <tel:4758437557
>>> <tel:4758437557>>,11.__1027935904,7.__
>>> 9434273599,7.__8361619299,7.__7610621969,7.__4929139614,5.__8106133327
>>> <tel:8106133327>
>>> <tel:8106133327
>>> <tel:8106133327>>,5.__9579132527,5.__9888473034,6.__5618433959
>>> <tel:5618433959>
>>> <tel:5618433959 <tel:5618433959>>,4.5013708887
>>> <tel:5013708887>
>>> <tel:5013708887
>>> <tel:5013708887>>,1.__9218516244,5.__7559805232,5.__2267081177
>>> <tel:2267081177>
>>> <tel:2267081177
>>> <tel:2267081177>>,5.0968196707,4.____8949133597,5.9137964962
>>> <tel:9137964962>
>>> <tel:9137964962
>>> <tel:9137964962>>,4.__2936059427,4.__6948533593,3.__4377318427
>>> <tel:4377318427>
>>> <tel:4377318427
>>> <tel:4377318427>>,3.7991617067,4.____
>>> 1242444467,3.8858731777,3.____9596393887,4.9192685996
>>> <tel:9192685996>
>>> <tel:9192685996
>>> <tel:9192685996>>,4.__6734033563,4.__
>>> 7511846457,4.__4544981945,4.__2748693367,3.__411559417,6.__
>>> 6851381985,6.__6744741285,6.__9296475385
>>> <tel:9296475385>,7.__0136847108,7.__
>>> 1371500908,7.__2719520708,6.__6787720528
>>> <tel:6787720528>,7.__3530295908,6.__8599596928
>>> <tel:8599596928>,7.__2216891568,7.__4951304208,7.__4404728868
>>> <tel:4404728868>,8.__1332243958,6.__
>>> 2736028029,6.__963685048,6.__0483763169,5.__8653351624
>>> <tel:8653351624>,5.__6164044005
>>> <tel:6164044005>,6.__54979166,5.__8783224469
>>> <tel:8783224469>,6.__533468297,5.__8553434082
>>> <tel:8553434082>,5.__7676662122,6.__267915357,5.__22607939
>>> 03,3.745459072,6.352470342,5.____4392033722,5.5562602522,5._
>>> ___3996670482,6.171297855,5.____648779598,5.5653279855,5.___
>>> _671668653,5.3243595462,5.____879320328,5.859442385
>>> <tel:5.859442385>,6.____080574272,5.
>>> 3767159992,6.____170852717,5.3001119472,5.____687201287,5.
>>> 3573110752,3.____586385579,5.566591422,5.____5104826925,5.
>>> 916268775,5.____4418422465,5.4037394705,5.____640889612,5.
>>> 1407657702,4.____5523677017,5.3873769863,3.____601570449,2.
>>> 978252449,4.____8725960282,4.9817842222,5.____2355359365,5.
>>> 1227105795,5.____177856607,5.098596533,5.____1891181988,4.
>>> 9327118245,4.____4632330777,7.4879538737,4.____8591269625,3.
>>> 1339054377,5.____8472818275,4.6043306952,3.____3542942377,4.
>>> 7660145915,6.____6679095357,5.51150886,2.____7404344677,5.
>>> 9332075344,6.____2019594857,5.266709364,5.____4924174224,5.
>>> 180577724,3.____0277711677,6.2913260157,4.____2862670877,5.
>>> 5461328154,5.____5809644644,5.1132029296,5.____1904326724,4.8352505633
>>> ,4.____9641930171,5.1366240426,7.____0699378037,3.
>>> 1274712477,5.____1487646306,5.2717034197,5.____0200090866,3.
>>> 0911490977,5.____8984613527,5.1973381747,4.__
>>> 2427530627,6.7293864957,4.____7943011637,5.1130266607,5.____
>>> 186371577,2.9723417287 <tel:9723417287> <tel:9723417287
>>> <tel:9723417287>>,2.3171875277,2.8159853427 <tel:8159853427>
>>> <tel:8159853427
>>> <tel:8159853427>>,__4.7913513947,4.7863347867 <tel:7863347867>
>>> <tel:7863347867
>>> <tel:7863347867>>,3.4531342837,__3.__
>>> 8161332287,5.8431115757,4.____4873126817,5.6577494097,5.____5867970832
>>> ,9.4583860946,2.____7784615917,5.4279953797,1.____9376872717
>>> ,5.0813930177,5.____8860618114,6.2411339874,6.____
>>> 4536904614,6.0972641874,5.____7247963284,5.9823452114,5.____8316140784
>>> ,5.2398164977,6.____2963392357,5.5864457124,6.____
>>> 1599995178,5.2609646384,6.____1012355027,6.4129483756,6.____
>>> 0056487896,5.0106569884,5.____4239402364,6.1148656496,2.____
>>> 673828844,4.3332873457,3.____2943586634,4.5834393467,7.____
>>> 278601561,3.5870893269,3.____3299191554,4.1049776549,5.____
>>> 9256568037,6.2719334873,6.____2594329923,5.5752581689,5.____
>>> 6058592867,6.1311384893,6.____4726413519,5.8973941434,6.____
>>> 2572672069,5.9667442136,5.____3965422637,7.2837623985,6.____
>>> 9586195092,7.1137641952,6.____3682104908,7.8495628418,7.____
>>> 2245886958,6.2983788278,7.____3509762248,6.9925366658,6.____
>>> 5600944468,6.936328733,6.____616665943,6.738732443}")
>>> RETURN QUERY
>>> QUERY
>>> RETURN QUERY
>>> QUERY
>>> NOTICE: ids: <NULL>
>>> RETURN QUERY
>>> QUERY
>>> not
>>> compatible for
>>> concatenation.
>>> line 25 at
>>> assignment
>>> QUERY
>>> QUERY
>>> I tried to write to Dose but he didn't reply yet.
>>> Does anyone have a clue?
>>> Try adding the follow line after the "begin" line:
>>> This should make sure the ids is initialized as an empty
>>> array of
>>> integers.
>>> -Steve
>>> Again:
>>> NOTICE: r2:
>>> (34304,"{0,5.3602868897 <tel:3602868897>,4.6782573327
>>> <tel:6782573327>,5.6026971537 <tel:6026971537>,5.2062747797
>>> <tel:2062747797>,5.__0497181017,5.3147719797,5.__
>>> 0700916462,4.3220066797,4.__8593618137,4.0002255227,6.__055760592,12.
>>> 5155379824,9.__3170226155,8.72783427270001,5.__9460446587,
>>> 3.0868131677,5.__1839796057,5.2301666167,2.__1211198847,5.
>>> 7037465591,2.__7282842677,8.4758437557,11.__1027935904,7.
>>> 9434273599,7.__8361619299,7.7610621969,7.__4929139614,5.
>>> 8106133327,5.__9579132527,5.9888473034,6.__5618433959,4.
>>> 5013708887,1.__9218516244,5.7559805232,5.__2267081177,5.
>>> 0968196707,4.__8949133597,5.9137964962,4.__2936059427,4.
>>> 6948533593,3.__4377318427,3.7991617067,4.__1242444467,3.
>>> 8858731777,3.__9596393887,4.9192685996,4.__6734033563,4.
>>> 7511846457,4.__4544981945,4.2748693367,3.__411559417,6.
>>> 6851381985,6.__6744741285,6.9296475385,7.__0136847108,7.
>>> 1371500908,7.__2719520708,6.6787720528,7.__3530295908,6.
>>> 8599596928,7.__2216891568,7.4951304208,7.__4404728868,8.
>>> 1332243958,6.__2736028029,6.963685048,6.__0483763169,5.
>>> 8653351624,5.__6164044005,6.54979166,5.__8783224469,6.
>>> 533468297,5.__8553434082,5.7
>> 676662122,6.__267915357,5.22607939
>>> 03,3.745459072,6.352470342,5.__4392033722,5.5562602522,5.__
>>> 3996670482,6.171297855,5.__648779598,5.5653279855,5.__
>>> 671668653,5.3243595462,5.__879320328,5.859442385,6.__
>>> 080574272,5.3767159992,6.__170852717,5.3001119472,5.__
>>> 687201287,5.3573110752,3.__586385579,5.566591422,5.__
>>> 5104826925,5.916268775,5.__4418422465,5.4037394705,5.__
>>> 640889612,5.1407657702,4.__5523677017,5.3873769863,3.__
>>> 601570449,2.978252449,4.__8725960282,4.9817842222,5.__
>>> 2355359365,5.1227105795,5.__177856607,5.098596533,5.__
>>> 1891181988,4.9327118245,4.__4632330777,7.4879538737,4.__
>>> 8591269625,3.1339054377,5.__8472818275,4.6043306952,3.__
>>> 3542942377,4.7660145915,6.__6679095357,5.51150886,2.__
>>> 7404344677,5.9332075344,6.__2019594857,5.266709364,5.__
>>> 4924174224,5.180577724,3.__0277711677,6.2913260157,4.__
>>> 2862670877,5.5461328154,5.__5809644644,5.1132029296,5.__
>>> 1904326724,4.8352505633,4.__9641930171,5.1366240426,7.__
>>> 0699378037,3.1274712477,5.__1487646306,5.2717034197,5.__
>>> 0200090866,3.0911490977,5.__8984613527,5.1973381747,4.__
>> 2427530627,6.7293864957,4.__7943011637,5.1130266607,5.__
>>> 186371577,2.9723417287 <tel:9723417287>,2.3171875277,2.8159853427
>>> <tel:8159853427>,__4.7913513947,4.7863347867
>>> <tel:7863347867>,3.4531342837,__3.8161332287,5.8431115757,4.__
>>> 4873126817,5.6577494097,5.__5867970832,9.4583860946,2.__
>>> 7784615917,5.4279953797,1.__9376872717,5.0813930177,5.__
>>> 8860618114,6.2411339874,6.__4536904614,6.0972641874,5.__
>>> 7247963284,5.9823452114,5.__8316140784,5.2398164977,6.__
>>> 2963392357,5.5864457124,6.__1599995178,5.2609646384,6.__
>>> 1012355027,6.4129483756,6.__0056487896,5.0106569884,5.__
>>> 4239402364,6.1148656496,2.__673828844,4.3332873457,3.__
>>> 2943586634,4.5834393467,7.__278601561,3.5870893269,3.__
>>> 3299191554,4.1049776549,5.__9256568037,6.2719334873,6.__
>>> 2594329923,5.5752581689,5.__6058592867,6.1311384893,6.__
>>> 4726413519,5.8973941434,6.__2572672069,5.9667442136,5.__
>>> 3965422637,7.2837623985,6.__9586195092,7.1137641952,6.__
>>> 3682104908,7.8495628418,7.__2245886958,6.2983788278,7.__
>>> 3509762248,6.9925366658,6.__5600944468,6.936328733,6.__
>>> QUERY
>>> QUERY
>>> NOTICE: ids: {}
>>> QUERY
>>> compatible for
>>> concatenation.
>>> assignment
>>> Thanks for your help. Maybe you need some other facts about my
>>> table?
>>> The whole script I am excecuting is the following. I changed some
>>> things, like adding your code and changing the table name 'ways'
>>> to
>>> 'cgn_2po_4pgr':
>>> sqlP
>>> text, OUT dmatrix double precision[], OUT ids integer[])
>>> as
>>> $body$
>>> declare
>>> sql text;
>>> sql2 text;
>>> r record;
>>> r2 record;
>>> i integer;
>>> j integer;
>>> begin
>>> FROM pgr_kdijkstraCost('''||sqlP||'__'', '||r.node||
>>> where
>>> id>'||r.id <http://r.id> <http://r.id>||'), false, false)
>>> matrixl := '{}';
>>> for i in 1..r.id <http://r.id> <http://r.id> loop
>>> dmatrix[i][r.id <http://r.id>
>>> <http://r.id>+1]);
>>> end loop;
>>> Sorry, I don't have a running version of this so this is somewhat
>>> guess work.
>>> -- ids := ids || r2.id1;
>>> ids := array_cat(ids, r2.id1);
>> try changing the line above to:
> Hi Steve, thank you. Back in office now but I'll try that later at home.
> I'll let you know and hopefully I get a good result :)
> Thanks so much.
> Carsten
>>> So comment out the old like and rewrite like this.
>>> -Steve
>>> Thanks for all your help Steve,
>>> hope, we're getting closer! Look, not it returns this:
>>> NOTICE: r2:
>>> NOTICE: ids: {}
>>> ERROR: function array_cat(integer[], integer) does not exist
>>> LINE 1: SELECT array_cat(ids, r2.id1)
>>> HINT: No function matches the given name and argument types. You might
>>> need to add explicit type casts.
>>> QUERY: SELECT array_cat(ids, r2.id1)
>>> CONTEXT: PL/pgSQL function "pgr_makedijkstramatrix" line 31 at
>>> assignment
>>> SQL Status:42883
>>> Hinweis:No function matches the given name and argument types. You might
>>> Kontext:PL/pgSQL function "pgr_makedijkstramatrix" line 31 at assignment
>>> Function does not exist? Still have an idea?
>>> Thanks
>>> Carsten
>>> end loop;
>>> end loop;
>>> end;
>>> $body$
>>> start_id integer, end_id integer default (-1))
>>> $body$
>>> declare
>>> sid integer;
>>> eid integer;
>>> begin
>>> ids as (
>>> rnum, id
>>> from (
>>> from dm
>>> ) foo
>>> t as (
>>> select a.seq, b.rnum, b.id <http://b.id> <http://b.id>
>>> from pgr_tsp(
>>> limit
>>> 1)::integer,
>>> rnum
>>> from ids where id=end_id limit 1) end)::integer
>>> ) a,
>>> ids b
>>> where a.id <http://a.id> <http://a.id>=b.rnum
>>> r as (
>>> dm.dmatrix[r.rnum[t.seq+1]+1][__r.rnum[(t.seq+1)%array_
>>> length(__r.rnum,
>>> from t, dm, r;
>>> end;
>>> $body$
>>> start_id
>>> $body$
>>> begin
>>> length::double
>>> start_id, end_id);
>>> end;
>>> $body$
>>> Maybe you've got another idea?
>>> Thank you
>>> Carsten
>>> Thanks for you help
>>> Carsten
>>> 2014-02-20 16:24 GMT+01:00 Stephen Woodbridge
>>> <mailto:woodbri at swoodbridge.__com <mailto:woodbri at swoodbridge.
>>> com>>
>>> <mailto:woodbri at swoodbridge.>____com
>>> <mailto:woodbri at swoodbridge.com>>>>:
>>> On 2/20/2014 9:41 AM, Stephen Woodbridge wrote:
>>> Hi Carsten,
>>> The functions at
>>> http://dose.0wnz.at/scripts/______sql/pgroute_tspDijkstra.sql
>>> <http://dose.0wnz.at/scripts/____sql/pgroute_tspDijkstra.sql>
>>> <http://dose.0wnz.at/scripts/__sql/pgroute_tspDijkstra.sql>>
>>> <http://dose.0wnz.at/scripts/sql/pgroute_tspDijkstra.sql>>>
>>> are not part of pgRouting.
>>> You need to ask this question to Ivan the
>>> author of the
>>> original
>>> article.
>>> Sorry, Dose was the original author.
>>> You probably need to add some debug statements
>>> to get a
>>> better
>>> understanding of what the code is doing. For
>>> example in
>>> pgr_makeDijkstraMatrix before the statement:
>>> ids := ids || array[r2.id1];
>>> You could try changing this line to:
>>> and see if that fixes the problem.
>>> -Steve
>>> Add:
>>> This should show you the progression of how
>>> the array
>>> ids is getting
>>> built as it appears to be compaining about
>>> that in the
>>> error
>>> message.
>>> Hope this helps,
>>> -Steve
>>> On 2/20/2014 9:21 AM, Carsten Hogertz wrote:
>>> Hi everybody, I am new to this list and
>>> new to
>>> pgrouting.
>>> I found the following TSP example
>>> http://hardwarefetish.com/513-______pgrouting-dijksta-____
>>> travelling-__salesman-problem-____tsp-with-__openstreetmap
>>> <http://hardwarefetish.com/513-____pgrouting-dijksta-__
>>> travelling-__salesman-problem-__tsp-with-__openstreetmap>
>>> <http://hardwarefetish.com/__513-__pgrouting-dijksta-__
>>> <http://hardwarefetish.com/513-__pgrouting-dijksta-
>>> travelling-__salesman-problem-tsp-with-__openstreetmap>>
>>> <http://hardwarefetish.com/____513-pgrouting-dijksta-____
>>> travelling-salesman-problem-____tsp-with-openstreetmap
>>> <http://hardwarefetish.com/__513-pgrouting-dijksta-__
>>> travelling-salesman-problem-__tsp-with-openstreetmap>
>>> <http://hardwarefetish.com/513-pgrouting-dijksta-
>>> travelling-salesman-problem-tsp-with-openstreetmap>>>
>>> and tried to reproduce the solution.
>>> Unfortunately I always get an error
>>> message.
>>> My DB is complaining about one of your
>>> functions.
>>> I got my routing table from osm2po. The
>>> table has
>>> the following
>>> structure:
>>> 1;”id”;”integer”
>>> 2;”osm_id”;”bigint”
>>> 3;”osm_name”;”character varying”
>>> 4;”osm_meta”;”character varying”
>>> 5;”osm_source_id”;”bigint”
>>> 6;”osm_target_id”;”bigint”;
>>> 7;”clazz”;”integer”
>>> 8;”flags”;”integer”
>>> 9;”source”;”integer”
>>> 10;”target”;”integer”
>>> 11;”length”;”double precision”
>>> 12;”kmh”;”integer”
>>> 13;”cost”;”double precision”
>>> 14;”reverse_cost”;”double precision”
>>> 15;”x1″;”double precision”
>>> 16;”y1″;”double precision”
>>> 17;”x2″;”double precision”
>>> 18;”y2″;”double precision”
>>> 19;”geom_way”;”geometry(______LineString,4326)”
>>> - I installed the functions as mentioned
>>> via SQL
>>> window in
>>> pgAdmin3
>>> (copy&paste then excecute)
>>> - I create and populate the my_route table
>>> - When it comes to step 5 and I try
>>> select id,lon,lat from
>>> pgr_tspDijkstraLen(’my_route’, 1260
>>> ) dj, my_route rt where dj.id2=rt.node;
>>> my DB warns
>>> arrays
>>> dimensions
>>> are not
>>> compatible for
>>> concatenation.
>>> “pgr_makedijkstramatrix”
>>> line 25 at
>>> assignment PL/pgSQL function
>>> “pgr_tspdijkstra” line
>>> 8 at
>>> RETURN QUERY
>>> PL/pgSQL function “pgr_tspdijkstralen”
>>> line 3 at
>>> RETURN QUERY
>>> arrays SQL
>>> Status:2202E
>>> dimensions are not
>>> compatible for
>>> concatenation.
>>> line 25
>>> at assignment
>>> PL/pgSQL function “pgr_tspdijkstra” line 8
>>> at
>>> RETURN QUERY
>>> line 3 at
>>> RETURN QUERY
>>> Do you have any idea what went wrong? I
>>> really
>>> really need your
>>> solutionget working. I would appreciate a
>>> lot.
>>> PS: this text is a copy of what I wrote on
>>> on the
>>> comment
>>> site of the
>>> blog where I found the solution.
>>> BR
>>> Carsten
>>> _____________________________________________________
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.______org
>>> <mailto:Pgrouting-users at lists.
>>> <mailto:Pgrouting-users at lists.>____osgeo.org <http://osgeo.org>
>>> <mailto:Pgrouting-users at lists.__osgeo.org
>>> <mailto:Pgrouting-users at lists.osgeo.org>>>
>>> http://lists.osgeo.org/______mailman/listinfo/pgrouting-___
>>> ___users
>>> <http://lists.osgeo.org/____mailman/listinfo/pgrouting-____users
>>> <http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users>>
>>> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>>>
>>> ___users
>>> ___users
>>> Pgrouting-users at lists.osgeo.____org
>>> Pgrouting-users at lists.osgeo.__org
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140225/521de587/attachment-0001.html>
More information about the Pgrouting-users
