[pgrouting-users] Issues with pgrouting workshop code in postgis2.11/pgrouting 2.0
Paragon Corporation
lr at pcorp.us
Fri Jan 3 18:45:15 PST 2014
Emmanuel,
That PHP code looks like it was written for pgRouting 1.0. Which workshop
did you get that from?
Most of the pgRouting 2.0 functions are prefixed with pgr_. There should be
a file in your install called
In C:/Program Files/PostgreSQL/9.2/share/extensions/pgrouting_legacy.sql
which installs the 1.0 function names. You could try using that though I
haven't personally had a need to.
One other thing I did notice about this code which I think is a bug is that
although PG_PORT is defined, it doesn't seem to be used for pg_connect, so
will not work without modification if you are runnning postgres on
non-default port (5432).
Hope that helps,
Regina
http://www.postgis.us
http://www.bostongis.com
http://www.paragoncorporation.com
_____
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Emmanuel
Adegboye
Sent: Friday, January 03, 2014 4:42 PM
To: pgrouting-users at lists.osgeo.org
Subject: [pgrouting-users] Issues with pgrouting workshop code in
I'm having issues getting the pgrouting workshop to work on Postgresql
9.2/PostGIS 2.11 and pgrouting 2.0 on windows.
How can I rewrite the following php/sql code and make it compatible with my
version:
<?php
// Database connection settings
define("PG_DB" , "routing");
define("PG_HOST", "localhost");
define("PG_USER", "postgres");
define("PG_PORT", "5432");
define("PG_PASSWD", "*******");
define("TABLE", "eastlegon");
$counter = $pathlength = 0;
// Retrieve start point
$start = split(' ',$_REQUEST['startpoint']);
$startPoint = array($start[0], $start[1]);
// Retrieve end point
$end = split(' ',$_REQUEST['finalpoint']);
$endPoint = array($end[0], $end[1]);
// Find the nearest edge
$startEdge = findNearestEdge($startPoint);
$endEdge = findNearestEdge($endPoint);
// FUNCTION findNearestEdge
function findNearestEdge($lonlat) {
// Connect to database
$con = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER."
password=".PG_PASSWD);
$sql = "SELECT gid, source, target, the_geom,
distance(the_geom, GeometryFromText(
'POINT(".$lonlat[0]." ".$lonlat[1].")', 4326)) AS dist
FROM ".TABLE."
WHERE the_geom && setsrid(
'BOX3D(".($lonlat[0]-200)."
".($lonlat[1]-200).",
".($lonlat[0]+200)."
".($lonlat[1]+200).")'::box3d, 4326)
ORDER BY dist LIMIT 1";
$query = pg_query($con,$sql);
$edge['gid'] = pg_fetch_result($query, 0, 0);
$edge['source'] = pg_fetch_result($query, 0, 1);
$edge['target'] = pg_fetch_result($query, 0, 2);
$edge['the_geom'] = pg_fetch_result($query, 0, 3);
// Close database connection
pg_close($con);
return $edge;
// Select the routing algorithm
switch($_REQUEST['method']) {
case 'SPD' : // Shortest Path Dijkstra
$sql = "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
length(rt.the_geom) AS length, ".TABLE.".id
FROM ".TABLE.",
(SELECT gid, the_geom
FROM dijkstra_sp_delta(
'".TABLE."',
".$startEdge['source'].",
".$endEdge['target'].",
3000)
) as rt
WHERE ".TABLE.".gid=rt.gid;";
break;
case 'SPA' : // Shortest Path A*
FROM ".TABLE.",
FROM astar_sp_delta(
'".TABLE."',
3000)
) as rt
break;
case 'SPS' : // Shortest Path Shooting*
FROM ".TABLE.",
FROM shootingstar_sp(
'".TABLE."',
".$startEdge['gid'].",
".$endEdge['gid'].",
3000, 'length', false, false)
) as rt
break;
} // close switch
// Database connection and query
$dbcon = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER."
$query = pg_query($dbcon,$sql);
// Return route as XML
$xml = '<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>'."\n";
$xml .= "<route>\n";
// Add edges to XML file
while($edge=pg_fetch_assoc($query)) {
$pathlength += $edge['length'];
$xml .= "\t<edge id='".++$counter."'>\n";
$xml .= "\t\t<id>".$edge['id']."</id>\n";
$xml .= "\t\t<wkt>".$edge['wkt']."</wkt>\n";
$xml .= "\t\t<length>".round(($pathlength/1000),3)."</length>\n";
$xml .= "\t</edge>\n";
$xml .= "</route>\n";
pg_close($dbcon);
// Return routing result
header('Content-type: text/xml',true);
echo $xml;
Thanks,
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140103/2cf80c44/attachment-0001.html>
More information about the Pgrouting-users
