[pgrouting-users] Issues with pgrouting workshop code in postgis2.11/pgrouting 2.0
sittichai choosumrong
sittichai.ocu at gmail.com
Tue Jan 7 15:47:23 PST 2014
Hi Emmanuel
If you want to make the old workshop works on pgRouting 2.0
>>> |<?php
>>> // Database connection settings
>>> define("PG_DB" , "routing");
>>> define("PG_HOST", "localhost");
>>> define("PG_USER", "postgres");
>>> define("PG_PORT", "5432");
>>> define("PG_PASSWD", "*******");
>>> define("TABLE", "eastlegon");
>>> $counter= $pathlength= 0;
>>> // Retrieve start point
>>> $start= split('',$_REQUEST['startpoint']);
>>> $startPoint= array($start[0], $start[1]);
>>> // Retrieve end point
>>> $end= split('',$_REQUEST['finalpoint']);
>>> $endPoint= array($end[0], $end[1]);
>>> // Find the nearest edge
>>> $startEdge= findNearestEdge($startPoint);
>>> $endEdge= findNearestEdge($endPoint);
>>> // FUNCTION findNearestEdge
>>> function findNearestEdge($lonlat) {
>>> // Connect to database
>>> $con= pg_connect("dbname=".PG_DB." host=".PG_HOST."
>>> user=".PG_USER." password=".PG_PASSWD);
>>> $sql= "SELECT gid, source, target, the_geom,
>>> distance(the_geom, GeometryFromText(
>>> 'POINT(".$lonlat[0]."".$lonlat[1].")', 4326)) AS
>>> dist
>>> FROM ".TABLE."
>>> WHERE the_geom && setsrid(
>>> 'BOX3D(".($lonlat[0]-200)."
>>> ".($lonlat[1]-200).",
>>> ".($lonlat[0]+200)."
>>> ".($lonlat[1]+200).")'::box3d, 4326)
>>> ORDER BY dist LIMIT 1";
>>> $query= pg_query($con,$sql);
>>> $edge['gid'] = pg_fetch_result($query, 0, 0);
>>> $edge['source'] = pg_fetch_result($query, 0, 1);
>>> $edge['target'] = pg_fetch_result($query, 0, 2);
>>> $edge['the_geom'] = pg_fetch_result($query, 0, 3);
>>> // Close database connection
>>> pg_close($con);
>>> return $edge;
>>> // Select the routing algorithm
>>> switch($_REQUEST['method']) {
>>> case 'SPD' : // Shortest Path Dijkstra
>>> $sql= "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
>>> length(rt.the_geom) AS length, ".TABLE.".id
>>> FROM ".TABLE.",
>>> (SELECT gid, the_geom
>>> FROM dijkstra_sp_delta(
>>> '".TABLE."',
>>> ".$startEdge['source'].",
>>> ".$endEdge['target'].",
>>> 3000)
>>> ) as rt
>>> WHERE ".TABLE.".gid=rt.gid;";
>>> break;
Here you have to change the function to pgRouting 2.0 using pgr_dijkstra
function as show below;
$sql = "SELECT w.gid, AsText(w.the_geom) AS wkt,w.name,
ST_length(w.the_geom) AS length, w.gid FROM ".TABLE." w,
(SELECT seq, id1 AS node, id2 AS edge,cost FROM pgr_dijkstra('
SELECT gid AS id,source::integer,
target::integer,
length::double precision AS cost
FROM ".TABLE."',
".$endEdge['target'].", false, false)
)as rt where w.gid=rt.edge;";
break;
It is works on my Computer using this code.
Best,
Bomp
Graduate School for Creative Cities
Urban Informatics
GIS Laboratory
Osaka City University 大阪市立大学
Sittichai Choosumrong
TEL +81-80-3812-2102
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140108/a4bb4794/attachment.html>
More information about the Pgrouting-users
