[pgrouting-users] Issues with pgrouting workshop code in postgis2.11/pgrouting 2.0
Emmanuel Adegboye eaadegboye at googlemail.com
Thu Jan 9 01:53:02 PST 2014
By the way, I followed Sittichai's code but I still got the same errors I
got earlier.
On 9 January 2014 10:48, Emmanuel Adegboye <eaadegboye at googlemail.com>wrote:
> Hello.
> I'm now working with the 2013 workshop now and I have my tables structured
> as follows:
> routing=# \d
>                       List of relations
>  Schema |             Name              |   Type   |  Owner
>  public | eastlegon                     | table    | postgres
>  public | eastlegon_gid_seq             | sequence | postgres
>  public | eastlegon_vertices_pgr        | table    | postgres
>  public | eastlegon_vertices_pgr_id_seq | sequence | postgres
>  public | eastlegonboundary             | table    | postgres
>  public | eastlegonboundary_gid_seq     | sequence | postgres
>  public | geography_columns             | view     | postgres
>  public | geometry_columns              | view     | postgres
>  public | raster_columns                | view     | postgres
>  public | raster_overviews              | view     | postgres
>  public | route                         | table    | postgres
>  public | spatial_ref_sys               | table    | postgres
> (12 rows)
> routing=# \d eastlegon
>                                       Table "public.eastlegon"
>     Column    |           Type            |
>  Modifiers
>  gid          | integer                   | not null default
> nextval('eastlegon_
> gid_seq'::regclass)
>  length       | double precision          |
>  class_id     | integer                   | not null
>  postcode     | character varying(254)    |
>  name         | character varying(100)    |
>  the_geom     | geometry(LineString,4326) |
>  source       | integer                   |
>  target       | integer                   |
>  cost_len     | double precision          |
>  cost_time    | double precision          |
>  rcost_len    | double precision          |
>  rcost_time   | double precision          |
>  x1           | double precision          |
>  y1           | double precision          |
>  x2           | double precision          |
>  y2           | double precision          |
>  to_cost      | double precision          |
>  rule         | text                      |
>  isolated     | integer                   |
>  reverse_cost | double precision          |
> Indexes:
>     "eastlegon_pkey" PRIMARY KEY, btree (gid)
>     "eastlegon_source_idx" btree (source)
>     "eastlegon_target_idx" btree (target)
>     "eastlegon_the_geom_gidx" gist (the_geom)
>     "source_idx" btree (source)
>     "target_idx" btree (target)
> My aim is simply to follow the workshop and display my routes using at
> least dijkstra algorithm in openlayers 2 (or 3 if it's not too
> complicated). I try installing the wrappers in the workshop but I get
> syntax errors.
> I'm sure my routing is properly set up since I can display routes using
> the pgRouting layer plugin for QGIS. I also have the layer stored properly
> in Geoserver. I can already display the layers as a WMS layer using
> openlayers. My only challenge is to display the route dynamically in a web
> browser.
> I need pointers in the right direction. My skills are still basic though,
> but I'm willing to learn.
> Thanks a lot for your help.
> Emmanuel
> On 4 January 2014 05:59, Stephen Woodbridge <woodbri at swoodbridge.com>wrote:
>> Emmanuel,
>> I wrote the legacy.sql more as an example to document how things changed,
>> but it was never tested as we did not plan on supporting it. The idea
>> behind it was to provide and an example to help people convert their
>> existing applications to use the new functions.
>> Part of the problem with the legacy code is that it had not test suite
>> and the code was very buggy. It also was haphazard because of its evolution
>> and random things being added that people thought might be nice to have.
>> The best thing to do is use the new workshop and if you have questions or
>> get stuck to ask the list and we will try to help you sort them out.
>> Best regards,
>>   -Steve
>> On 1/3/2014 11:28 PM, Emmanuel Adegboye wrote:
>>> Regina.
>>> It was from the foss4g 2007 workshop. The most recent worshops include
>>> wrapper functions which I am not familiar with so I also get stuck at
>>> some point.
>>> What I am trying to do is to create a simple application that allows
>>> users to set a start and end point and calculate the route using any one
>>> of the major algorithms like the workshop describes.
>>> So far, the user interface (based on openlayers 2.10) works well and
>>> displays both points. I get an error in firebug when I click the
>>> 'calculate route' button and the php script is called, and this was
>>> after I installed legacy.sql. I get "ERROR: type "geoms" does not exist"
>>> when installing pgrouting.sql.
>>> Here's the error from firebug:
>>> |<br />
>>> ||<b>Warning</b>:  pg_query(): Query failed: ERROR:  parse error -
>>> invalid geometry
>>> ||HINT:  "POINT( )" <-- parse error at position 9 within
>>> geometry in <b>C:\ms4w\Apache\htdocs||\hgt\routing.php</b> on line
>>> <b>42</b><br />
>>> ||<br />
>>> ||<b>Warning</b>:  pg_fetch_result() expects parameter 1 to be resource,
>>> boolean given in <b>C:\ms4w\Apache||\htdocs\hgt\routing.php</b> on line
>>> <b>44</b><br />
>>> ||<br />
>>> <b>45</b><br />
>>> ||<br />
>>> <b>46</b><br />
>>> ||<br />
>>> <b>47</b><br />
>>> ||<br />
>>> invalid geometry
>>> <b>42</b><br />
>>> ||<br />
>>> <b>44</b><br />
>>> ||<br />
>>> <b>45</b><br />
>>> ||<br />
>>> <b>46</b><br />
>>> ||<br />
>>> <b>47</b><br />
>>> ||<br />
>>> ||<b>Warning</b>:  pg_query(): Query failed:  in
>>> <b>C:\ms4w\Apache\htdocs\hgt\routing.php</b> on line||<b>108</b><br />
>>> ||<br />
>>> ||<b>Warning</b>:  pg_fetch_assoc() expects parameter 1 to be resource,
>>> <b>115</b><br />
>>> ||<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
>>> ||<route>
>>> ||</route>|
>>> And the html document:
>>> <!DOCTYPE html>
>>> <html>
>>> <head>
>>> <title>pgRouting Demo</title>
>>> <link rel="stylesheet" href="openlayers/theme/default/style.css"
>>> type="text/css">
>>> <style>
>>> #map-id {
>>> width: 100%;
>>> height: 512px;
>>> border: 1px solid black;
>>> </style>
>>> <script src="openlayers/OpenLayers.js"></script>
>>> </head>
>>> <body>
>>> <div id="map-id"></div>
>>> <script>
>>> var SinglePoint = OpenLayers.Class.create();
>>> SinglePoint.prototype = OpenLayers.Class.inherit(OpenLayers.Handler.Point,
>>> createFeature: function(evt) {
>>> this.control.layer.removeFeatures(this.control.layer.features);
>>> OpenLayers.Handler.Point.prototype.createFeature.apply(this, arguments);
>>> var start_style = OpenLayers.Util.applyDefaults({
>>> externalGraphic: "start.png",
>>> graphicWidth: 18,
>>> graphicHeight: 26,
>>> graphicYOffset: -26,
>>> graphicOpacity: 1
>>> }, OpenLayers.Feature.Vector.style['default']);
>>> var stop_style = OpenLayers.Util.applyDefaults({
>>> externalGraphic: "stop.png",
>>> graphicWidth: 18,
>>> graphicHeight: 26,
>>> graphicOpacity: 1
>>> var result_style = OpenLayers.Util.applyDefaults({
>>> strokeWidth: 3,
>>> strokeColor: "#ff0000",
>>> fillOpacity: 0
>>> // global variables
>>> var map, parser, start, stop, result, controls;
>>> var format = 'image/png';
>>> var bounds = new OpenLayers.Bounds(
>>>                      -0.178166372987693, 5.62323476776518,
>>>                      -0.140817506885068, 5.64840001174401
>>> var options = {
>>>                      controls: [],
>>>                      maxExtent: bounds,
>>>                      maxResolution: 0.0001458940082134,
>>>                      projection: "EPSG:4326",
>>>                      units: 'degrees'
>>> map = new OpenLayers.Map("map-id", options);
>>> boundary = new OpenLayers.Layer.WMS(
>>>                      "East Legon - Boundary",
>>> "http://localhost:8080/geoserver/pgrouting/wms",
>>>                          LAYERS: 'pgrouting:eastlegonboundary',
>>>                          STYLES: '',
>>>                          format: format,
>>>                          tiled: true,
>>>                          tilesOrigin : map.maxExtent.left + ',' +
>>> map.maxExtent.bottom
>>>                          buffer: 0,
>>>                          displayOutsideMaxExtent: true,
>>>                          isBaseLayer: true,
>>>                          yx : {'EPSG:4326' : true}
>>> eastlegon = new OpenLayers.Layer.WMS(
>>>                      "East Legon",
>>>                          LAYERS: 'pgrouting:eastlegon',
>>>                          STYLES: '',
>>>                          format: format,
>>> transparent: true,
>>>                          tiled: true,
>>>                          buffer: 0,
>>>                          isBaseLayer: false,
>>> start = new OpenLayers.Layer.Vector("Start Point", {style: start_style});
>>> stop = new OpenLayers.Layer.Vector("End Point", {style: stop_style});
>>> result = new OpenLayers.Layer.Vector("Routing Results",
>>> {style: result_style});
>>> map.addLayers([boundary, eastlegon, start, stop, result]);
>>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>>> map.addControl(new OpenLayers.Control.PanPanel());
>>> map.addControl(new OpenLayers.Control.ZoomPanel());
>>> map.addControl(new OpenLayers.Control.ScaleLine());
>>> map.addControl(new OpenLayers.Control.Navigation());
>>> map.addControl(new OpenLayers.Control.MousePosition());
>>> map.zoomToExtent(bounds);
>>> // controls
>>> controls = {
>>> start: new OpenLayers.Control.DrawFeature(start, SinglePoint),
>>> stop: new OpenLayers.Control.DrawFeature(stop, SinglePoint)
>>> for (var key in controls) {
>>> map.addControl(controls[key]);
>>> function toggleControl(element) {
>>> for (key in controls) {
>>> if (element.value == key && element.checked) {
>>> controls[key].activate();
>>> } else {
>>> controls[key].deactivate();
>>> function compute() {
>>>              var startPoint = start.features[0];
>>>              var stopPoint = stop.features[0];
>>>              if (startPoint && stopPoint) {
>>>                  var result = {
>>>                      startpoint: startPoint.geometry.x + ' ' +
>>> startPoint.geometry.y,
>>>                      finalpoint: stopPoint.geometry.x + ' ' +
>>> stopPoint.geometry.y,
>>>                      method: OpenLayers.Util.getElement('method').value,
>>>                      region: "eastlegon",
>>>                      srid: "4326"
>>>                  OpenLayers.loadURL("./routing.php",
>>>   OpenLayers.Util.getParameterString(result),
>>>                                     null,
>>>                                     displayRoute);
>>>          function displayRoute(response) {
>>>              if (response && response.responseXML) {
>>>                  // erase the previous results
>>>                  result.removeFeatures(result.features);
>>>                  // parse the features
>>>                  var edges =
>>> response.responseXML.getElementsByTagName('edge');
>>>                  var features = [];
>>>                  for (var i = 0; i < edges.length; i++) {
>>>                      var g =
>>> parser.read(edges[i].getElementsByTagName('wkt')[0].textContent);
>>>                      features.push(new OpenLayers.Feature.Vector(g));
>>>                  result.addFeatures(features);
>>> </script>
>>> <ul>
>>> <li>
>>> <input type="radio" name="control" id="noneToggle"
>>> onclick="toggleControl(this);" checked="checked" />
>>> <label for="noneToggle">navigate</label>
>>> </li>
>>> <li>
>>> <input type="radio" name="control" value="start" id="startToggle"
>>> onclick="toggleControl(this);" />
>>> <label for="startToggle">set start point</label>
>>> </li>
>>> <li>
>>> <input type="radio" name="control" value="stop" id="stopToggle"
>>> <label for="stopToggle">set stop point</label>
>>> </li>
>>> </ul>
>>> <select id="method">
>>> <option value="SPD">Shortest Path Dijkstra - undirected (BBox)</option>
>>> <option value="SPA">Shortest Path A Star - undirected</option>
>>> <option value="SPS">Shortest Path Shooting Star</option>
>>> </select>
>>> <button onclick="compute()">Calculate Route</button>
>>> </body>
>>> </html>
>>> On Jan 4, 2014 3:45 AM, "Paragon Corporation" <lr at pcorp.us
>>> <mailto:lr at pcorp.us>> wrote:
>>>     __
>>>     Emmanuel,
>>>     That PHP code looks like it was written for pgRouting 1.0. Which
>>>     workshop did you get that from?
>>>     Most of the pgRouting 2.0 functions are prefixed with pgr_. There
>>>     should be a file in your install called
>>>       In C:/Program
>>>     Files/PostgreSQL/9.2/share/extensions/pgrouting_legacy.sql which
>>>     installs the 1.0 function names.  You could try using that though I
>>>     haven't personally had a need to.
>>>     One other thing I did notice about this code which I think is a bug
>>>     is that although PG_PORT is defined, it doesn't seem to be used for
>>>     pg_connect, so will not work without modification if you are
>>>     runnning postgres on non-default port (5432).
>>>     Hope that helps,
>>>     Regina
>>>     http://www.postgis.us
>>>     http://www.bostongis.com
>>>     http://www.paragoncorporation.com
>>>     *From:* pgrouting-users-bounces at lists.osgeo.org
>>>     <mailto:pgrouting-users-bounces at lists.osgeo.org>
>>>     [mailto:pgrouting-users-bounces at lists.osgeo.org
>>>     <mailto:pgrouting-users-bounces at lists.osgeo.org>] *On Behalf Of
>>>     *Emmanuel Adegboye
>>>     *Sent:* Friday, January 03, 2014 4:42 PM
>>>     *To:* pgrouting-users at lists.osgeo.org
>>>     <mailto:pgrouting-users at lists.osgeo.org>
>>>     *Subject:* [pgrouting-users] Issues with pgrouting workshop code in
>>>     I'm having issues getting the pgrouting workshop to work on
>>>     Postgresql 9.2/PostGIS 2.11 and pgrouting 2.0 on windows.
>>>     How can I rewrite the following php/sql code and make it compatible
>>>     with my version:
>>>     |<?php
>>>        // Database connection settings
>>>        define("PG_DB"   ,  "routing");
>>>        define("PG_HOST",  "localhost");
>>>        define("PG_USER",  "postgres");
>>>        define("PG_PORT",  "5432");
>>>         define("PG_PASSWD",    "*******");
>>>        define("TABLE",    "eastlegon");
>>>        $counter=  $pathlength=  0;
>>>        // Retrieve start point
>>>        $start=  split('',$_REQUEST['startpoint']);
>>>        $startPoint=  array($start[0],  $start[1]);
>>>        // Retrieve end point
>>>        $end=  split('',$_REQUEST['finalpoint']);
>>>        $endPoint=  array($end[0],  $end[1]);
>>>        // Find the nearest edge
>>>        $startEdge=  findNearestEdge($startPoint);
>>>        $endEdge=  findNearestEdge($endPoint);
>>>        // FUNCTION findNearestEdge
>>>        function  findNearestEdge($lonlat)  {
>>>          // Connect to database
>>>          $con=  pg_connect("dbname=".PG_DB." host=".PG_HOST."
>>> user=".PG_USER." password=".PG_PASSWD);
>>>          $sql=  "SELECT gid, source, target, the_geom,
>>>                   distance(the_geom, GeometryFromText(
>>>                        'POINT(".$lonlat[0]."".$lonlat[1].")', 4326)) AS
>>> dist
>>>                  FROM ".TABLE."
>>>                  WHERE the_geom && setsrid(
>>>                        'BOX3D(".($lonlat[0]-200)."
>>>                               ".($lonlat[1]-200).",
>>>                               ".($lonlat[0]+200)."
>>>                               ".($lonlat[1]+200).")'::box3d, 4326)
>>>                  ORDER BY dist LIMIT 1";
>>>          $query=  pg_query($con,$sql);
>>>          $edge['gid']       =  pg_fetch_result($query,  0,  0);
>>>          $edge['source']    =  pg_fetch_result($query,  0,  1);
>>>          $edge['target']    =  pg_fetch_result($query,  0,  2);
>>>          $edge['the_geom']  =  pg_fetch_result($query,  0,  3);
>>>          // Close database connection
>>>          pg_close($con);
>>>          return  $edge;
>>>        // Select the routing algorithm
>>>        switch($_REQUEST['method'])  {
>>>          case  'SPD'  :  // Shortest Path Dijkstra
>>>            $sql=  "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
>>>                         length(rt.the_geom) AS length, ".TABLE.".id
>>>                      FROM ".TABLE.",
>>>                          (SELECT gid, the_geom
>>>                              FROM dijkstra_sp_delta(
>>>                                  '".TABLE."',
>>>                                  ".$startEdge['source'].",
>>>                                  ".$endEdge['target'].",
>>>                                  3000)
>>>                           ) as rt
>>>                      WHERE ".TABLE.".gid=rt.gid;";
>>>            break;
>>>          case  'SPA'  :  // Shortest Path A*
>>>                        FROM ".TABLE.",
>>>                                FROM astar_sp_delta(
>>>                                    '".TABLE."',
>>>                                    3000)
>>>                             ) as rt
>>>     _______________________________________________
>>>     Pgrouting-users mailing list
>>>     Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.
>>> osgeo.org>
>>>     http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140109/b35f02f4/attachment-0001.html>
More information about the Pgrouting-users mailing list
