[pgrouting-users] All Nearest Neighbors
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jun 6 13:28:06 PDT 2014
On 6/6/2014 3:56 PM, Brian DeRocher wrote:
> Does pgrouting have an algorithm to solve All Nearest Neighbors. I'd
> rather not run Dijkstra's or A* n times.
> I'm working on a project of build US congressional districts based on
> a k-means clustering of citizen residences. But i want to use the
> driving distance for the distance function. This is like asking,
> what's the closest post office for every person. It's more work than
> A*, but it seems to me, less work than all pairs shortest path. Am i
> wrong?
> http://en.wikipedia.org/wiki/Nearest_neighbor_search#All_nearest_neighbors
> If not, i'll work on it, where's a good place to start.
> Brian
Brian,
The short answer is no.
You can look at the driving distance function where you give it a start
point and it computes the code to all node in the network as you expand
out from there.
You can also look at pgr_kdijkstra() which gives you a one to many
solution but you have to give it a list of the "many" points you want
the answers to.
In K-means, every time you add a point to a cluster you have to
recompute the cluster centroid so because the centroid changed locations
your "all nearest neighbors" needs to be recomputed.
I think the driving distance function is probably your best bet.
-Steve
More information about the Pgrouting-users
