[pgrouting-users] TRSP Problem
Christophe Damour sigeal at sigeal.com
Fri Mar 7 10:41:45 PST 2014
No answer... I am stuck with this one.
Is it possible that there is a conflict between the where clause
processing and the cost / rev_cost ?
I have the same behaviour with edge start / target instead of vertex
start / target.
Here is the wrong query result :
seq 	id1 	id2 	cost
0 	19314 	23805 	25.2230680696244
1 	16327 	15869 	200.551744693165
2 	16328 	30606 	1000000
3 	22180 	30607 	12.1375967381755
4 	14374 	28286 	249.361944927019
5 	14371 	18295 	111.604786405456
6 	10776 	-1 	0
In my understanding, it shouldn't be possible to have an edge with cost
1000000 in the resulting path (it is the only one in the network to have
such a cost, and the network is very small) !
Thanks for any hint,
Christophe DAMOUR
Le 03/03/2014 20:20, Christophe Damour a écrit :
> Hi,
> Sorry to post twice, I forgot the attached file...
> I use pgRouting to calculate accessible routes for disabled pedestrians.
> Network edges have some attributes that are used to filter the
> accessible network in both ways depending on the user capacities
> (where clause).
> Network edges have also attributes that are used to update cost /
> rev_cost depending on the routing way : If an edge is forbidden in the
> digitizing way, cost is set to 1 000 000. If it is forbidden in the
> reverse way, rev_cost is set to 1 000 000. If it is forbidden in both
> ways, cost and rev_cost are set to  1 000 000.
> Now, in some cases, despite there is no accessible route according to
> the where clause, pgr_trsp() returns a route going through edges with
> cost / rev_cost set to 1 000 000.
> If I change the where clause so that there is actually an alternative
> route, same edges with cost / rev_cost set to 1 000 000 are taken into
> account, and the calculated route is correct.
> I attached to this message images of both results (forbidden edges in
> red, returned paths in blue).
> Routing is calculated from edge n°18295 (vertex n°19314) to edge
> n°23805 (vertex n°10776).
> Wrong edge is n°30606 in test 2.
> Here is the sql code of the first test :
> SELECT * FROM pgr_trsp(
> 'SELECT id_tron::integer AS id, source::integer, target::integer,
> cost::double precision, rev_cost::double precision AS reverse_cost
> FROM rp_test
> WHERE type_tron NOT IN(3, 8, 9) AND largeur_c > 90 AND largeur_p > 75
> AND etat_revet >= 2',
> 19314::INTEGER, 10776::INTEGER, true, true,
> 'SELECT to_cost::double precision, target_id::integer, via_path::text
> FROM reseau_global_rest');
> And here is the sql code of the second test :
> FROM rp_test
> WHERE type_tron NOT IN(3, 8, 9) AND largeur_c > 90 AND largeur_p > 75',
> I also attach to this message a shape file of the network.
> Do I miss something, or is it a bug ?
> Thanks for any help,
> Christophe DAMOUR
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140307/70579f7f/attachment-0001.html>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140307/70579f7f/attachment-0001.bin>
More information about the Pgrouting-users mailing list
