[pgrouting-users] (SOLVED) TRSP returns "Start id was not found"
Vladimir
fl_v at inbox.ru
Sat Mar 8 10:52:22 PST 2014
Hi Stephen,
I added new issue about a couple of bugs pgr_createTopology :
https://github.com/pgRouting/pgrouting/issues/240
Thanks very much for you efforts.
Best regards.
>Hi Vladimir,
>This is a good catch!
>Can you please write a bug on this issue so we remember to resolve it in
>the next release.
>Glad you got this working.
>Thanks,
> -Steve
>On 3/7/2014 5:45 AM, Vladimir wrote:
>> Hi again.
>> As written in the documentation
>> < for" target="_blank"> http://docs.pgrouting.org/2.0/en/src/trsp/doc/index.html#trsp>for SQL
>> statement of TRSP:
>> id: int4 identifier of the edge
>> But pgr_createTopology function creates new "noded" table with "id" of
>> bigint type.
>> I've solved this problem by casting "id" to integer type.
>> Now that's works:
>> SELECT seq, id1 AS node, id2 AS edge, cost FROM pgr_trsp('SELECT
>> id::integer,source::integer,target::integer,cost::float FROM edge_tab',
>> 138, 0.5, 161, 0.5, false, false);
>> Thanks very much to author of this
>> < http://pgrouting-users.974093.n3.nabble.com/pgrouting-users-Shortest-Path-TRSP-td3782221.html >
>> post for idea.
>> Best regards.
>> Hello All!
>> I try to use TRSP with source_edge/target_edge syntax:
>> id,source::integer,target::integer,cost::float FROM edge_tab', 138,
>> but the error "Start id was not found" occurs.
>> Edges with ids 138 and 161 exists in edge_tab that's checked by
>> SELECT * FROM edge_tab WHERE id in (138,161)
>> pgr_version: 2.0.0,pgrouting-2.0.0,0,f26831f,master,1.53.0
>> Please could you tell me what's wrong ?
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> < /compose?To=Pgrouting%2dusers at lists.osgeo.org >
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140308/627297ce/attachment.html>
More information about the Pgrouting-users
