[pgrouting-users] Problems installing version 2.0
George Silva
georger.silva at gmail.com
Wed Mar 12 05:54:40 PDT 2014
Hello everyone,
I'm trying to install 2.0 version of pgrouting and I can't.
I've tried on a brand new server, but it complains about cgal9 and cgal8.
Here are the logs:
george at atlas:~/projetos/pleno.rotas/src$ sudo aptitude install
postgresql-9.1-pgrouting
The following NEW packages will be installed:
postgresql-9.1-pgrouting{b}
0 packages upgraded, 1 newly installed, 0 to remove and 10 not upgraded.
Need to get 255 kB of archives. After unpacking 924 kB will be used.
The following packages have unmet dependencies:
postgresql-9.1-pgrouting : Depends: libcgal9 which is a virtual package. or
libcgal8 which is a virtual package.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) postgresql-9.1-pgrouting [Not Installed]
Accept this solution? [Y/n/q/?] y
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
This log came from my dev machine.
I've used the build-dep command from aptitude, and tried again. libcgal-dev
was installed.
Do I need to install any dependencies? I won't need the functionality cgal
provides (DD), so this should be installed without problems.
Any tips?
Thanks
George R. C. Silva
SIGMA Consultoria
http://www.consultoriasigma.com.br/
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140312/a2fb6fb0/attachment.html>
More information about the Pgrouting-users
