[pgrouting-users] Different results - pgr_dijkstra/pgr_kdijkstrapath/cost/pgr_ksp
Omar Fernando Pessôa
omar.pessoa at gmail.com
Tue Mar 25 07:45:17 PDT 2014
I have a city roads data base witch is returning different values from this
'selects'.
select sum(cost) from pgr_Dijkstra('SELECT id, source, target, cost,
reverse_cost FROM ruas', 3423, 3839, true, true);
select sum(cost) from pgr_kdijkstraPath('SELECT id, source, target, cost,
reverse_cost FROM ruas', 3423, array[3839], true, true);
select sum(cost) from pgr_ksp('SELECT id, source, target, cost,
reverse_cost FROM ruas', 3423, 3839, 1, true);
Manually I have seen that the pgr_Dijkstra has the correct path.
And the others has passed from edges who is not the shortest path.
Is it an alghorithm error?
*Omar Fernando Pessôa*
http://www.opessoa.com
Desenvolvedor de sistemas
Programador C# e C++
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140325/376e6f5f/attachment.html>
More information about the Pgrouting-users
