[pgrouting-users] Function to result routes/costs from single_origin to multi-destinations
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Nov 15 05:22:47 PST 2014
On 11/15/2014 3:12 AM, AUS - Eyad wrote:
> Thank you Daniel, and All..
> I rephrased the code and adjusted it accordingly:
> select
> id,
> the_geom,
> (pgr_kdijkstraCost(
> 'SELECT id, source, target, st_length(geom) as cost FROM schema.cvl',
> 1, array[98, 100, 220, 320, 650], false, false
> )) as cost
> from schema.cvl_vertices_pgr WHERE id=1
> Here I could calculate the costs of different destinations from the
> source_point#1, but I still seek advices, as follows:
> 1)Is there a way to automatically insert all the destination/target
> points in the array? I tried ‘SELECT id FROM schema.cvl_vertices_pgr’,
> but didn’t work!
select array_agg(id) from schema.cvl_vertices_pgr
> 2)I transferred the vector and points features from AutoCAD. How can I
> control the units (i.e. I used meters in CAD but it seems to be
> millimeters here – e.g. Cost to point#98 = 112959.0)
Don't know how you transferred them so I can not say, but you can also
use st_length(geom) * factor to scale your data.
> 3)I tried the same contents of the function on “pgr_kdijkstraPath” but
> it didn’t work! What could be the problem?
Not enough information and too many variables to give help.
What was your query?
what was the results?
Why do you think it did not work?
Have you read the 2.0 documentation?
Have you found the pgrouting 2.0 workshop and tutorials and worked
through them?
Thanks,
-Steve
> Regards,
> Eyad
> *From:*pgrouting-users-bounces at lists.osgeo.org
> [mailto:pgrouting-users-bounces at lists.osgeo.org] *On Behalf Of *Daniel Kastl
> *Sent:* Monday, November 10, 2014 4:11 AM
> *To:* pgRouting users mailing list
> *Subject:* Re: [pgrouting-users] Function to result routes/costs from
> On Mon, Nov 10, 2014 at 3:42 AM, AUS - Eyad <b00038807 at aus.edu
> <mailto:b00038807 at aus.edu>> wrote:
> While applying the following tutorial:
> http://anitagraser.com/2011/02/09/creating-catchment-areas-with-pgrouting-and-qgis/
> utilizing vector network which has been tested (and demonstrated
> functionality) for shortest path application, it returned the following
> message:
> Hi,
> I think the tutorial was written before pgRouting 2.0 was released.
> It may require some changes.
> LAST COMMENT.. If you know another code/method that helps in
> multi-routing from one point to list of targets to result routes and
> costs from single-origin (source) to multi-destinations (targets),
> please provide guidance.. origins and destinations are in a single
> points feature (i.e. cvl_vertices_pgr), whereas routes calculation
> shall take place in lines feature (i.e. cvl).
> If you need 1 -> n shortest path queries, then you could try pgr_kDijkstra:
> http://docs.pgrouting.org/2.0/en/src/kdijkstra/doc/index.html#pgr-kdijkstra
> Best regards,
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.info
> *_Original Message:_*
> message:
> Query returned successfully: 1013 rows affected, 199 ms execution time
> but returned no table as output!
> The code I used is:
> create table catchment_1 as select id, the_geom, (select sum(cost) from
> ( SELECT * FROM pgr_dijkstra( 'SELECT id, source, target,
> st_length(geom) as cost FROM schema.cvl', 1, 320, false, false )) as foo
> ) as cost from schema.cvl_vertices_pgr
> I also tried passing "id" to the function instead of "320" as per the
> tutorial but got the following msg:
> ERROR: function pgr_dijkstra(unknown, integer, bigint, boolean, boolean)
> does not exist SQL state: 42883
> Although, pgr_dijkstra is working well with other codes.. so, it's one
> of the recognized functions in my installed pgRouting layer
> I'm using QGIS 2.0.1 and pgRouting pg93-binaries-2.4.0
> In order to gradually test the code, I started by the inner SELECT then
> went up step by step.. I got result table for each step until I reached
> the highest SELECT in the structure.. I got a table showing the cost for
> each point_id. the special result is a point feature.. but what drew my
> attention in the result table is that all costs are exactly the same
> '32430.028' whereas the points are non-regularly distributed.. This
> means that I just needed to remove 'create table catchment_1 as' to get
> a result table, but still the cost values do not seem to make sense.
> points feature (i.e. cvl_vertices_pgr), whereas routes calculation shall
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
