[pgrouting-users] pgr Create Topology question
John Zabrenski
jwzabrenski at gmail.com
Wed Oct 1 13:41:49 PDT 2014
Hi Steve,
I tested this with a two part build of the state of Rhode Island and it
succeeded. Did a test of pgr_drivingdistance and got results that look
normal (http://goo.gl/lYY7Hc).
So in the near future I will be attempting the build of the US street
network and will let you know of any developments.
Thanks for your assistance,
John
On Tue, Sep 30, 2014 at 11:05 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Hello John,
> Vicky has developed a new version of create topology that supports
> incremental build of the topology.
> https://github.com/cvvergara/pgrouting/tree/commonFunctions
> This will get merged into pgrouting at some point, but it would be great
> if you wanted to give it a try and report if you have problems. We have
> done some basic testing but it sounds like you have a great test case for
> this.
> You can clone her repository and build pgrouting from that source and then
> you should have access to those new functions. Vicky is on the list so if
> you need help or run into issues, give a shout and let us know how it goes.
> Since you are on windows, it might be easier to just take the plpgsql code
> from her source and install it without trying to build everything.
> -Steve
> On 9/30/2014 5:20 PM, John Zabrenski wrote:
>> Hello everyone,
>> I have a question about pgr_createTopology...
>> I am attempting to make a routable US street network table using
>> pgRouting (pgRouting ver 2.0.0, postGIS 2.1.1, postgresql 9.2).
>> It is running on localhost (32 bit windows, 4 gb RAM).
>> I have a postgres table created originally from street shapefiles that
>> now has about 43 million rows.
>> As I expected, the create topology function faced an out of memory error
>> about halfway through the creation, and gave me this message:
>> My original statement:
>> SELECT pgr_createTopology('usa_streets', 0.00001, 'geom', 'gid');
>> Result:
>> NOTICE: out of memory
>> NOTICE: UPDATE public.usa_streets SET source = 22148149,target =
>> 22152619 WHERE gid = 9166028
>> Total query runtime: 96149189 ms.
>> 1 row retrieved.
>> The resulting vertices_pgr table has only about 22 million rows and I
>> get errors for null sources when trying to run routing functions.
>> Would it be possible to run another Create Topology for rows in the
>> original edges table where source and target are null, or will this just
>> create two conflicting networks?
>> I am curious if anyone here is familiar or experienced with a workaround
>> for this problem? Or is the only solution more RAM? If I'm leaving out
>> any relevant information please let me know.
>> Thank you for reading,
>> John Zabrenski
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20141001/3aae4426/attachment.html>
More information about the Pgrouting-users
