[pgrouting-users] Could not load library librouting.dll error
Paragon Corporation
lr at pcorp.us
Mon Aug 10 09:29:08 PDT 2015
Yes. The binaries get created by Winnie and I test and package to push to
stack builder and also copy to http://download.osgeo.org/postgis/windows/
So they are always available on her first and released on osgeo
-----Original Message-----
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of McDonaldR
Sent: Monday, August 10, 2015 12:01 PM
To: 'pgRouting users mailing list' <pgrouting-users at lists.osgeo.org>
Subject: Re: [pgrouting-users] Could not load library librouting.dll error
Thank you Regina
It would be good to test that. Will the binaries also be available from
winnie.postgis.net? We operate behind a firewall and cannot use the stack
builder.
Ross
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: 10 August 2015 16:14
I had to upgrade the gcc I am using for building with PostgreSQL 9.2 and
also they made a change in PostgreSQL 9.2 micros around 9.2.5 or so that is
incompatible with older postgresql 9.2 that forced a recompile of some
things.
I'll build a new PostgreSQL 9.2 and pgRouting 2.0.0 and test with latest 9.2
64-bit. If it goes well I'll push to application stack builder (PostgreSQL
9.2 PostGIS 2.1.8 and pgRouting 2.0.0)
Let me spin up a 9.2 64-bit to test with and see what's up.
Thanks,
Regina
Sent: Monday, August 10, 2015 10:59 AM
To: pgRouting users mailing list <pgrouting-users at lists.osgeo.org>
Thanks for the reply, Dave
I've tried with the PATH set to both:
Path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\Syst
em32
\WindowsPowerShell\v1.0\;D:\Php;D:\Php\ext;D:\PostgreSQL\9.2\bin;D:\PostgreS
QL\9.2\lib
And:
em32
I wonder if it is something to do with the way PostgreSQL, PostGIS and
PgRouting are compiled? Looking at
http://winnie.postgis.net/download/windows/pg92/buildbot/ there are versions
compiled with GCC4.8 and others with something else. I've tried all the
64bit binary versions there with no luck.
Ross
dave.potts at pinan.co.uk
Sent: 10 August 2015 15:28
Hi
What is the environmental variable path set to ?
You can get its value by opening a dos window and typing set
This variable lists the folders that an application will search through to
find library files.
You can change its value by selecting control panel-->Adminstrative Tools->
Right click on computer select properties-> select advanced system settings
and the envrionment variable button is on the lower right hand side
The value should be a list off folders to search seperated by a ; character.
Dave
#> Hello list,
> I am running 64bit PostgreSQL 9.2.13 with PostGIS 2.1.7 on Windows
> Server
> 2008 R2. I have pgRouting installed (2.0.0 build 40, hash 567ac3b,
> boost
> 1.46.1)
> I am getting an error when trying to use pgRouting.
> [ERROR: could not load library "D:/PostgreSQL/9.2/lib/librouting.dll":
> The specified procedure could not be found.
> SQL state: 58P01]
> SQL state error 58P01 is UNDEFINED FILE.
> Using dependency walker it tells me that librouting.dll cannot find
> libgcc_s_sjlj-1.dll and libstdc++-6.dll and postgres.exe. These files
> all exist in the \bin folder of my PostgreSQL install. The PgRouting
> files are all installed in the \lib folder.
> I get the error when using both the PgAdmin SQL pane and the pgRouting
> Layer plugin in QGIS.
> Any pointers or suggestions appreciated.
> Thanks
> Ross
> Ross McDonald | GIS Data Coordinator | Resources Department, IT
> Division | Angus Council, Angus House, Orchardbank Business Park,
> Forfar, DD8 1AT
> T: 01307 476419 | F: 01307 476401 | E:
> mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk>
> This message is strictly confidential. If you have received this in
> error, please inform the sender and remove it from your system. If
> received in error you may not copy, print, forward or use it or any
> attachment in any way. This message is not capable of creating a legal
> contract or a binding representation and does not represent the views
> of Angus Council. Emails may be monitored for security and network
> management reasons. Messages containing inappropriate content may be
> intercepted. Angus Council does not accept any liability for any harm
> that may be caused to the recipient system or data on it by this
> message
or any attachment.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
This message is strictly confidential. If you have received this in error,
please inform the sender and remove it from your system. If received in
error you may not copy, print, forward or use it or any attachment in any
way. This message is not capable of creating a legal contract or a binding
representation and does not represent the views of Angus Council. Emails may
be monitored for security and network management reasons. Messages
containing inappropriate content may be intercepted. Angus Council does not
accept any liability for any harm that may be caused to the recipient system
or data on it by this message or any attachment.
More information about the Pgrouting-users
