[pgrouting-users] Error updating to PgRouting 2.1.0 (Pg 9.3.9, 32bit)
Paragon Corporation lr at pcorp.us
Wed Aug 12 05:45:46 PDT 2015
Ross,
This might be just a windows packaging issue or you picked up an interim 2.0
when you installed.
I had this issue once, and I think the problem is you were maybe running 2.0
develop which shows as 2.0.0, but really isn't 2.0.0.  It's somewhere
between 2.0.0 and 2.1.0
You can tell because the actual released version have branch master or tag
like this:
2.0.0;pgrouting-2.0.0;0;f26831f;master;1.53.0
Anyway you say you are testing with 9.3 32-bit. I'll look into that to make
sure I didn't mispackage the 2.0.0 on the 9.3 32-bit.
If I didn't then its just you installed the 2.0 package instead of the 2.0.0
package originally.
I don't think any tables actually depend on pgRouting so if you don't have
any SQL functions built on it,  it's safe to just delete pgrouting extension
and reinstall it.
Plpgsql are opaque anyway so the use of pgRouting in them will not force
them to drop when you drop the pgRouting extension.
Thanks,
Regina
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of McDonaldR
Sent: Wednesday, August 12, 2015 5:24 AM
To: pgrouting-users at lists.osgeo.org
Subject: [pgrouting-users] Error updating to PgRouting 2.1.0 (Pg 9.3.9,
32bit)
Hello list,
I get an error message when trying to update pgRouting from 2.0.0 to 2.1.0
in a Postgresql 9.3.9 32bit database on Windows 7.
ALTER EXTENSION pgrouting UPDATE TO "2.1.0";
ERROR: function pgr_alphashape(text) does not exist
SQL state: 42883
I am using this build of pgRouting -
http://winnie.postgis.net/download/windows/pg93/buildbot/pgrouting-pg93-bina
ries-2.1.0-betaw32gcc481.zip
Currently installed version is:
"2.0.0";"pgrouting-2.0.0";"40";"567ac3b";"develop";"1.53.0"
Was hoping to get:
2.1.0, pgrouting-2.1.0-alpha1, 81, 5fa89b2, develop_2_1_0, 1.58.0
For some context, the pgr_alphashape function currently installed in my
database is:
-- Function: public.pgr_alphashape(text, double precision)
-- DROP FUNCTION public.pgr_alphashape(text, double precision);
CREATE OR REPLACE FUNCTION public.pgr_alphashape(IN sql text, IN alpha
double precision DEFAULT 0, OUT x double precision, OUT y double precision)
  RETURNS SETOF record AS
'$libdir/librouting_dd', 'alphashape'
  LANGUAGE c IMMUTABLE STRICT
  COST 1
  ROWS 1000;
The new alphashape function to be created looks like this:
CREATE OR REPLACE FUNCTION pgr_alphashape(sql text, alpha float8 DEFAULT 0,
OUT x float8, OUT y float8)
    AS '$libdir/librouting-2.1', 'alphashape'
    LANGUAGE c IMMUTABLE STRICT;
Is it best to post these here or should I use Github issues?
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division |
Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E:  <mailto:mcdonaldr at angus.gov.uk>
This message is strictly confidential. If you have received this in error,
please inform the sender and remove it from your system. If received in
error you may not copy, print, forward or use it or any attachment in any
way. This message is not capable of creating a legal contract or a binding
representation and does not represent the views of Angus Council. Emails may
be monitored for security and network management reasons. Messages
containing inappropriate content may be intercepted. Angus Council does not
accept any liability for any harm that may be caused to the recipient system
or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150812/64c701b3/attachment-0001.html>
More information about the Pgrouting-users mailing list
