[pgrouting-users] TRSP error - Invalid result geometry node_id:-1edge_id:0
McDonaldR McDonaldR at angus.gov.uk
Tue Aug 18 08:27:48 PDT 2015
Regina,
Using the 2.1.0 version ["2.1.0";"pgrouting-2.1.0-alpha1";"81";"5fa89b2";"develop_2_1_0";"1.58.0"] on my Windows 7 32bit PC the problem is indeed fixed.
TRSP works with and without reverse costs, with and without turn restrictions and with both vertices and edges.
Huge thanks to you, Steve, Ko and Vicky (and others) for all the work that goes into making pgRouting better and better.  It is much appreciated.  I am going to be running a couple of short training sessions using pgRouting shortly after showing a couple of live examples at our internal GIS user group that piqued interest.
Ross
From: pgrouting-users-bounces at lists.osgeo.org [mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Paragon Corporation
Sent: 18 August 2015 14:29
To: 'pgRouting users mailing list'
Subject: Re: [pgrouting-users] TRSP error - Invalid result geometry node_id:-1edge_id:0
Ross,
Were you able to try the 2.1.0 beta binaries?
This issue should be fixed on those.
Thanks,
Regina
From: pgrouting-users-bounces at lists.osgeo.org<mailto:pgrouting-users-bounces at lists.osgeo.org> [mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of McDonaldR
Sent: Tuesday, August 18, 2015 8:53 AM
To: pgrouting-users at lists.osgeo.org<mailto:pgrouting-users at lists.osgeo.org>
Subject: [pgrouting-users] TRSP error - Invalid result geometry node_id:-1edge_id:0
Hello list
I am getting an error using the pgr_trsp function with vertices.
[Invalid result geometry node_id:-1 edge_id:0] using the pgRouting Layer plugin in QGIS
The query is:
SELECT *
FROM pgr_trsp('SELECT gid as id, source::integer, target::integer, cost_len::float AS cost
FROM itn_network',
 30,
60,
 false,
 false
Result
0;-1;0;0 using PgAdmin
If I use the function with edges then it works as expected
SELECT *
FROM itn_network',
 2958, 0.5,
1194, 0.5,
 false,
 false
Result
0;-1;2958;302.909919799321
1;21;12;3289.06571781744
2;22;2534;0
3;1841;1484;0
4;1063;669;657.261388446325
5;1062;671;306.606908032689
6;1064;2381;0
7;428;241;0
8;427;69391;0
9;1504;1104;0
10;1069;675;0
11;1066;672;0
12;430;242;0
13;429;1763;0
14;506;290;814.718952140309
15;507;1157;206.661904345321
16;505;69401;394.173213311315
17;2093;69400;1152.8033703581
18;24;1156;0
19;1109;712;911.407628015424
20;1110;69367;82.6836380428031
21;2275;2954;55.7924940561552
22;2818;69406;10.2909471381108
23;2262;2171;93.7878062207647
24;1548;1148;0
25;1547;1543;0
26;1901;2178;0
27;1546;2172;0
28;1897;1540;0
29;1542;1968;22.2622766251952
30;495;284;0
31;494;2612;0
32;499;286;0
33;498;69364;0
34;1557;1155;0
35;1556;1154;0
36;1555;2603;0
37;146;79;0
38;145;1981;35.7573399535413
39;148;80;0
40;147;2994;0
41;2842;2996;0
42;26;14;0
43;25;1170;0
44;1572;2993;0
45;1133;736;0
46;1132;737;0
47;1134;1173;0
48;1136;739;0
49;150;82;1139.31607861894
50;151;1175;267.426016400421
51;1197;794;0
52;604;349;0
53;603;2077;0
54;1941;1589;0
55;1604;1206;0
56;1196;793;0
57;1195;1207;0
58;1189;788;491.087128220612
59;1190;789;300.17025240827
60;1191;1586;122.598743787454
61;167;1840;0
62;171;92;0
63;170;1579;0
64;1593;1199;0
65;1592;68167;0
66;1183;1828;0
67;1933;1578;0
68;1932;1985;0
69;1595;1200;0
70;1594;1984;26.9342460479565
71;1931;1577;67.4166151627323
72;1181;782;312.414537400116
73;1179;781;0
74;1180;68143;0
75;591;341;0
76;590;772;0
77;1167;68151;0
78;1170;773;0
79;1169;774;0
80;1171;1194;0
Any suggestions on how to debug this?  Using the same two vertices with the Djikstra functions works fine.
I am running it on Postgresql 9.2.13 64bit with PostGIS 2.1.7 and pgRouting 2.0.0
"POSTGIS="2.1.7 r13414" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.7.8" LIBJSON="UNKNOWN" TOPOLOGY RASTER"
"2.0.0";"pgrouting-2.0.0";"0";"f26831f";"master";"1.53.0"
Thanks
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk>
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150818/5a7e14c0/attachment-0001.html>
More information about the Pgrouting-users mailing list
