[pgrouting-users] pgr_drivingdistance problem
Vicky Vergara
vicky_vergara at hotmail.com
Fri Aug 28 21:19:12 PDT 2015
Hello Jim
I executed your query, I am not getting the same results as you are.
Right now we are in the process of releasing pgRouting 2.1
I used the pgr_DrivingDistance developed for the 2.1 version.
The github branch develop has the latest but its changing a lot during this days.
Vicky
Date: Fri, 28 Aug 2015 20:45:45 -0400
To: pgrouting-users at lists.osgeo.org; postgis-users at lists.osgeo.org
Subject: [pgrouting-users] pgr_drivingdistance problem
When I run pgr_drivingdistance
on an small extract (578 rows) (attached) from an extract
of Pennsylvania's osm pbf file not all edges are being
followed.
I first downloaded the pbf. Then I imported it with osm2pgrouting
osmosis --read-pbf file=pennsylvania-latest.osm.pbf --write-xml pennsylvania-latest.osm
osm2pgrouting -file pennsylvania-latest.osm -conf /usr/share/osm2pgrouting/mapconfig.xml -dbname osm3 -user jim -skipnodes -passwd hunter2
and then running
CREATE TABLE smallways AS
SELECT * FROM ways
WHERE ST_DISTANCE(the_geom, ST_GEOMFROMTEXT('POINT(-79.900121 40.448889)', 4326)) < 0.2;
and creating the appropriate indices to build a test environment
(the output of which
is the small extract (578 rows)(attached)).
To test pgr_drivingdistance, I did the following:
CREATE OR REPLACE VIEW testing AS
SELECT gid,
the_geom
FROM ( SELECT
seq,
id1 AS vertext_id,
id2 AS gid,
cost
FROM pgr_drivingdistance(
'SELECT gid AS id, source, target,
length AS cost, reverse_cost
FROM smallways',
179103,
0.5,
false,
true) ) t
INNER JOIN smallways USING (gid);
and then loading that view into QGIS, I see the following:
Why are some edges not being selected? I initially thought it was
the (source, target) (labels in screenshot) ordering,
but that doesn't seem to be the case, as some edges such as 148517
to the SW of the annotated starting point, seems to be in good
order.
Jim
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150828/64754341/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150828/64754341/attachment-0002.png>
Name: Screenshot - 08282015 - 075732 PM.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150828/64754341/attachment-0001.jpg>
Name: Screenshot - 08282015 - 075732 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150828/64754341/attachment-0003.png>
More information about the Pgrouting-users
