[pgrouting-users] Pgrouting-users Digest, Vol 77, Issue 4
Eric Scheibler
email at eric-scheibler.de
Fri Feb 13 08:14:11 PST 2015
Hello Omar,
I've tested my function with the Postgresql version 9.1. I discovered, that the "=>" operator is
marked as deprecated. So maybe it was removed in a newer Postgresql version. Try to replace with the
following line:
vertex_storage = vertex_storage || hstore(row.source::text, new_vertex::text);
And another hint: The routing table must have an index at the source and target columns like this:
CREATE INDEX idx_tmp_routing_source ON tmp_routing_table USING btree (source);
CREATE INDEX idx_tmp_routing_target ON tmp_routing_table USING btree (target);
Otherwise it's much slower.
And here is the full function again:
CREATE OR REPLACE FUNCTION recreate_vertex_of_routing_table(regclass)
RETURNS void
AS $$
DECLARE
row RECORD;
vertex_storage hstore;
new_vertex int;
BEGIN
vertex_storage := ''::hstore;
new_vertex := 1;
FOR row in EXECUTE FORMAT('SELECT id, source, target FROM %I', $1)
LOOP
IF NOT vertex_storage ? row.source::text THEN
new_vertex := new_vertex + 1;
END IF;
IF NOT vertex_storage ? row.target::text THEN
vertex_storage = vertex_storage || hstore(row.target::text, new_vertex::text);
END IF;
END LOOP;
FOR row IN SELECT key, value FROM EACH(vertex_storage)
LOOP
EXECUTE FORMAT('UPDATE %I SET source=$1 WHERE source = $2', $1) USING row.value::int, row.key::int;
EXECUTE FORMAT('UPDATE %I SET target=$1 WHERE target = $2', $1) USING row.value::int, row.key::int;
END LOOP;
END;
$$ LANGUAGE plpgsql;
Hope, it helps
Best regards
Eric
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150213/aff577ca/attachment.pgp>
More information about the Pgrouting-users
