[pgrouting-users] Routing via different Layers/Levels
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jan 6 10:11:38 PST 2015
https://github.com/pgRouting/pgrouting/wiki/Create-Topology-With-Z-Levels-at-Intersections
On 1/6/2015 11:48 AM, AUS - Eyad wrote:
> Hi Steve,
> You somehow pointed to what I need. The only difference is:
> 1) my case includes 2 networks overlapping by (x,y) over most of the
> sections (one of them shall be completely lifted). Two full networks which
> shall connect only where Ramps (with 2 different z-level_edges) are located.
> (Nodes/Edges shall not be duplicated because they exist)
> 2) the case you presented has only one node where there is 2 different (z
> coordinates). (This node shall be duplicated).
> I would appreciate it if you could send me sample code/link for cloning of
> pgr_createTopology to support 3D because unfortunately I'm not a programmer.
> Regards,
> Eyad
> -----Original Message-----
> From: pgrouting-users-bounces at lists.osgeo.org
> [mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Stephen
> Woodbridge
> Sent: Tuesday, January 6, 2015 1:26 AM
> To: pgrouting-users at lists.osgeo.org
> Subject: Re: [pgrouting-users] Routing via different Layers/Levels
> Hi Eyad,
> I'm a little confused as to what you are trying to do. Just to be clear:
> pgr_nodeNetwork() is for creating nodes and splitting edges the
> intersect but do not have a node at the intersection.
> NOTE: there has recently been some bugs reported against 2.0
> pgr_nodeNetwork() and there might be a pull request. Check the tickets.
> pgr_createtopology() is takes a nodded network and assigns the nodes to
> the edges.
> Typically networks that have overpass/underpass that should not be
> connected, use a zlevel at each end of the segment. So you might
> represent an over pass like:
> E(0)
> ----B(1)-----
> A(0)---/ B(0) \-----C(0)
> D(0)
> A-B-C is a highway overpass
> B-B-E is a highway underpass
> (n) is the zlevel
> So B(0) and B(1) have the same x-y position but they are not connected
> together.
> You can make a fairly simple clone to pgr_createtopology() to take the
> zlevel*factor as the z value of a point with the x-y values and check
> for 3D distance between the nodes. This will result in the B(0) and B(1)
> getting assigned different node ids and the related segments will then
> not be connected.
> I have some old code floating about that does this, but it is a simple
> change if you wanted to do it yourself.
> If this is not what you are asking about, sorry, please give more
> details on what you are trying to accomplish.
> -Steve
> On 1/5/2015 3:57 PM, AUS - Eyad wrote:
>> Hi All,
>> Is there a way to conduct nodding for part of a network instead of the
>> whole network in order to restrict routing through specific channels
>> (i.e. 2 layers network where access is restricted via ramps)?
>> I tried the below 2 codes:
>> 1)select pgr_nodeNetwork('schema.network_table',50,'id','geom') FROM
>> schema.network_table where (Layer='first_level');
>> 2)select pgr_nodeNetwork('schema.network_table' where
>> (Layer='first_level'),50,'id','geom');
>> The first is entering endless loop processing the data; the second is
>> returning a syntax Error (@WHERE)!
>> I know that the second sounds clearly wrong code, but I provided the
>> above example trying to brain-storm with all.
>> If there is no option to do the required while nodding or
>> creating_topology, is it possible to utilize 2 separately_noded networks
>> (instead of the below highlighted one) within the following code?
>> SELECT seq, id1 as source, id2 as target, cost FROM pgr_kdijkstraCost(
>> 'SELECT id, source, target, (st_length(geom) * 0.001) as cost FROM
>> *_schema.network_table_noded_*',
>> (SELECT id FROM schema.p_table WHERE id=1), (SELECT array_agg(id)
>> FROM schema.p_table), false, false
>> Please advise suitable/potential code..
>> Happy New Year to ALL
>> Eyad
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2015.0.5577 / Virus Database: 4257/8875 - Release Date: 01/05/15
More information about the Pgrouting-users
