[pgrouting-users] Reg: Get nearest node in osm data
Manikanta Kondeti
mani.iiit123 at gmail.com
Tue Jun 23 14:03:57 PDT 2015
Hi Steve,
Thanks a lot for your response.
On Wed, Jun 24, 2015 at 1:55 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 6/23/2015 3:56 PM, Manikanta Kondeti wrote:
>> Hi,
>> I am writing a small application to get the route on the map. I am
>> using openlayers.js on client and pgrouting as a backend routing library
>> for my project. When a click is triggered I get a lat, lon, and I have
>> the osm data in postgres which is loaded using osm2pgrouting. I'll pass
>> this lat,lon to server and I have to find the nearest node id from this
>> lat,lon. Can I query the database and get it done? Help me out.
> Probably you want to do this in two steps:
> 1. find the nearest edge
> 2. find the nearest node along the edge
> Anyway your queries will be something like:
This is working perfect and found the nearest edge.
> -- get the closest edge
> select * from edges where st_dwithin(geom, st_setsrid(st_makepoint(long,
> lat), 4326), maxdist) order by st_distance(geom,
> st_setsrid(st_makepoint(long, lat), 4326)) asc limit 1;
This is giving me syntax error. I've added the screenshot
> -- get closest node along edge
> select case when st_line_locate_point(geom,st_setsrid(st_makepoint(long,
> lat), 4326)) < 0.5 then source else target from edges edge_id=id
This is not giving me any nearest nodes. I've this screenshot as well.
> -- or search to just get the closest node
> select * from nodes where st_dwithin(geom, st_setsrid(st_makepoint(long,
> where:
> maxdist - maximum distance to search for geometries in db units probably
> degrees
> long, lat - values for the location in question
> id - is the id of the closest edge found in the first query
Let me know if I miss something.
Thanks,
Mani
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150624/e0c842f9/attachment-0001.html>
Name: Screen Shot 2015-06-24 at 2.30.06 AM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150624/e0c842f9/attachment-0002.png>
Name: Screen Shot 2015-06-24 at 2.33.45 AM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150624/e0c842f9/attachment-0003.png>
More information about the Pgrouting-users
