[pgrouting-users] pgr_kdijkstraCost- how to use array with braces?
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Thu Sep 17 10:31:39 PDT 2015
On 9/17/2015 12:25 PM, Bistrais, Bob wrote:
> Hello,
> I am trying to work with pgRouting’s pgr_kdijkstraCost to find multiple
> paths.  The input requires an array of target nodes enclosed by brackets
> [].  But when I generate the array in Postgres, the array is enclosed in
> braces {}.  So I can’t get the algorithm to work.
> Can anyone suggest how to make this array work with the
> pgr_kdijkstraCost algorithm?
Hi Bob,
I would be helpful if you showed you sql that didn't work. But here is a
go in a vacuum:
Define a static array in postgres with:
     array[item, item, item, ...]
     '{item, item, item, ...}'::integer[] -- cast string to integer array
Define an array as an aggregrate:
     select array_agg(id) from some_table;
Combining these:
     select * from pgr_kdijkstraCost(..., (select array_agg(id) from
some_table), ...);
     select * from pgr_kdijkstraCost(..., array[1,2,3,27,35,...], ...);
'{1,2,3,27,35,...}'::integer[], ...);
-Steve
More information about the Pgrouting-users
