[pgrouting-users] Sources, sinks and flows
Andrea Nardelli nrd.nardelli at gmail.com
Wed Apr 13 03:50:09 PDT 2016
Hi all,
I have been looking into flow algorithms for pgRouting and it is also my
application for GSoC.
If you have any ideas or just want to discuss, please let me know.
Andrea
On Wed, Apr 13, 2016 at 8:16 AM, <dave.potts at pinan.co.uk> wrote:
> Hi All,
> I would just say that the boost library is already well used in the
> pgrouting and the code required to link the algorithms suggested by Vicky
> could be done by copy the bulk of the current code.
> Dave.
> 13 April 2016 00:38, "Vicky Vergara" <vicky at georepublic.de
> <%22Vicky%20Vergara%22%20%3Cvicky at georepublic.de%3E>> wrote:
> Hello Rhys:
> For the moment we don't have any flow algorithms, but we want to
> incorporate into pgRouting the following boost Graph algorithms:
>    1. Maximum Flow and Matching Algorithms
>       1. edmonds_karp_max_flow
>       <http://www.boost.org/doc/libs/1_60_0/libs/graph/doc/edmonds_karp_max_flow.html>
>       2. push_relabel_max_flow
>       <http://www.boost.org/doc/libs/1_60_0/libs/graph/doc/push_relabel_max_flow.html>
>       3. boykov_kolmogorov_max_flow
>       <http://www.boost.org/doc/libs/1_60_0/libs/graph/doc/boykov_kolmogorov_max_flow.html>
>       4. edmonds_maximum_cardinality_matching
>       <http://www.boost.org/doc/libs/1_60_0/libs/graph/doc/maximum_matching.html>
>    2. Minimum Cost Maximum Flow Algorithms
>       1. cycle_canceling
>       <http://www.boost.org/doc/libs/1_60_0/libs/graph/doc/cycle_canceling.html>
>       2. successive_shortest_path_nonnegative_weights
>       <http://www.boost.org/doc/libs/1_60_0/libs/graph/doc/successive_shortest_path_nonnegative_weights.html>
>       3. find_flow_cost
>       <http://www.boost.org/doc/libs/1_60_0/libs/graph/doc/find_flow_cost.html>
> I don't know if any of those might serve your purposes.
> So, if you start writing code, please let us know, so we can give you a
> hand on how to use the pgRouting internal library.
> On Tue, Apr 12, 2016 at 6:25 PM, Rhys A.D. Stewart <rhys.stewart at gmail.com
> > wrote:
> Greetings all,
> This is my first foray into the world of pgrouting. I'm particularly
> interested in sources and flows. I have a graph which I want to give
> direction based on one or more nodes being a source, and another set of
> nodes being blockers (I'm representing an electric network). I only saw one
> mention of sources/sinks in the pgrouting docs. I'm asking before I start
> writing code that may not need to be written.
> Rhys
> Peace & Love|Live Long & Prosper
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG (haftungsbeschränkt) Salzmannstraße 44, 81739 München, Germany Vicky Vergara Operations Research eMail: vicky at georepublic.de Web: https://georepublic.info Tel: +49 (089) 4161 7698-1 Fax: +49 (089) 4161 7698-9 Commercial register: Amtsgericht München, HRB 181428 CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160413/68a92fbc/attachment-0001.html>
More information about the Pgrouting-users mailing list
