[pgrouting-users] pgr_withPoints not working correctly
Vicky Vergara
vicky at georepublic.de
Thu Apr 14 22:43:25 PDT 2016
Josep:
Your explanation is very clear, thanks for testing.
Please open an issue with this bug. (while I start working on it)
https://github.com/pgRouting/pgrouting/issues
Just for your information: one of the reasons that the new functionality is
placed as proposed functions because of bugs that might still be there.
Thanks again for trying it out.
Vicky
On Thu, Apr 14, 2016 at 1:03 PM, Josep Lopez Xarbau <jlopez at tecnocampus.cat>
wrote:
> Hi, I’ve tried this function and it seems not to work correctly. When it
> calculates the route between vertex it does well, but when using the
> pointsofinterest, it confuses the ids of the points and the result is
> incorrect.
> If we take a look at the example:
> *Example:*
> From point 1 to point 3
> SELECT * FROM pgr_withPoints(
> 'SELECT id, source, target, cost, reverse_cost FROM edge_table
> ORDER BY id',
> 'SELECT pid, edge_id, fraction, side from pointsOfInterest',
> -1, -3);
> seq | path_seq | node | edge | cost | agg_cost
> 1 | 1 | -1 | 1 | 0.6 | 0
> 2 | 2 | 2 | 4 | 1 | 0.6
> 3 | 3 | 5 | 7 | 1 | 1.6
> 4 | 4 | 8 | 6 | 0.7 | 2.6
> 5 | 5 | -3 | -1 | 0 | 3.3
> (5 rows)
> If we follow the edges, we’ll see that it begins from the point 1 but ends
> at point 4. Edges sequence(1,4,7,6)
> [image: ../../../_images/Fig1-originalData.png]
> These are the correspondences of the points
> Point of ‘Pointsofinterest’ Point used by pgr_withpoints
> 1
> 1
> 2
> 5
> 3
> 4
> 4
> 2
> 5
> 3
> 6
> 6
> Hope I explained myself clearly, and sorry for my English (;P).
> Josep.
> *CONFIDENCIALITAT*
> Aquesta informació és confidencial, personal i intransferible i només va
> dirigida a la/les adreça/ces indicades. Qualsevol modificació,
> retransmissió, difusió o altre ús d'aquesta informació per persones o
> entitats diferents a la persona a qui va dirigida està prohibida. Si vostè
> l'ha rebut per error, li preguem que ho reenviï a *desconegut at tecnocampus.cat
> <desconegut at tecnocampus.com>*, i esborri el missatge original juntament
> amb els seus fitxers annexos sense llegir-lo ni gravar-lo. Gràcies.
> Abans d'imprimir-lo, assegura't de que és realment necessari.
> *EL MEDI AMBIENT ÉS COSA DE TOTS.*
> *CONFIDENCIALIDAD *La presente información es confidencial, personal e
> intransferible y sólo va dirigida a la/s dirección/es indicadas. Cualquier
> modificación, retransmisión, difusión u otro uso de esta información por
> personas o entidades diferentes a la persona a la que va dirigida está
> prohibida. Si usted lo ha recibido por error, le rogamos que lo reenvie a
> desconegut at tecnocampus.com, y borre el mensaje original junto con sus
> ficheros anexos sin leerlo ni grabarlo. Gracias.
> Antes de imprimir, asegúrese que es realmente necesario hacerlo.
> *EL MEDIO AMBIENTE ES COSA DE TODOS.*
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160415/78e1febb/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160415/78e1febb/attachment-0001.png>
More information about the Pgrouting-users
