[pgrouting-users] Problem with query
Worth Lutz wal3 at mindspring.com
Fri Jul 1 09:07:17 PDT 2016
Hi Steve,
That method gives the expected results running in psql on the command line.
In pgAdmin, I got the previous results with no values in the id2 column.
I can get the missing id2 with SELECT pgr_bdDijkstra(..) on pgAdmin also.
Confusion reigns here today!
I'll see if I can get a test case put together.
*Worth Lutz*
On 7/1/2016 11:48 AM, Stephen Woodbridge wrote:
> What do you get if you do:
> SELECT (pgr_bdDijkstra(...)).*
> You should probably write this up as an issue.
> -Steve
> On 7/1/2016 11:08 AM, Worth Lutz wrote:
>> Hi All,
>> Can anyone explain the strange results (see below) I'm getting?
>> ~$ apt-show-versions postgresql
>> postgresql:all/trusty-updates 9.3+154ubuntu1 uptodate
>> ~$ apt-show-versions postgis
>> postgis:amd64/trusty 2.1.4+dfsg-3~trusty uptodate
>> ~$ apt-show-versions postgresql-9.3-pgrouting
>> postgresql-9.3-pgrouting:amd64/trusty 2.2.3-release-ppa1~trusty1
>> uptodate
>> The first query gives me 4 values and the second has the 'id2' value
>> empty.
>> SELECT
>>     pgr_bdDijkstra(
>>     'SELECT id_base AS id, source, target, cost_len AS cost, rcost_len
>> AS reverse_cost FROM _rt_geom_streets_base',
>>     11, 6, TRUE, TRUE
>>          pgr_bddijkstra
>>  (0,11,2087858,482.722955703)
>>  (1,3549,2082803,275.837140233)
>>  (2,24976,2086339,272.953707069)
>>  (3,20623,2086101,484.096255058)
>>  (4,48115,2085508,388.315542378)
>>  (5,47218,2084557,480.30350456)
>>  (6,8387,2094458,476.8149761)
>>  (7,248,2093906,255.35844989)
>>  (8,1348,2097029,247.294429215)
>>  (9,1536,2090136,339.718631568)
>>  (10,6465,2091005,330.978413622)
>>  (11,3740,2087980,415.137012292)
>>  (12,1504,2095856,375.236169771)
>>  (13,1505,2090458,466.482679764)
>>  (14,1130,2089855,481.831396537)
>>  (15,1116,2089664,470.256648783)
>>  (16,1117,2139494,262.774003918)
>>  (17,2907,2139496,73.1337200735)
>>  (18,765,2131538,172.32970181)
>>  (19,6,-1,0)
>> (20 rows)
>> SELECT *
>>   FROM
>> pgr_bdDijkstra(
>>     11, 6, TRUE, TRUE
>>  seq |  id1  | id2 |     cost
>>    0 |    11 |     | 482.722955703
>>    1 |  3549 |     | 275.837140233
>>    2 | 24976 |     | 272.953707069
>>    3 | 20623 |     | 484.096255058
>>    4 | 48115 |     | 388.315542378
>>    5 | 47218 |     |  480.30350456
>>    6 |  8387 |     |   476.8149761
>>    7 |   248 |     |  255.35844989
>>    8 |  1348 |     | 247.294429215
>>    9 |  1536 |     | 339.718631568
>>   10 |  6465 |     | 330.978413622
>>   11 |  3740 |     | 415.137012292
>>   12 |  1504 |     | 375.236169771
>>   13 |  1505 |     | 466.482679764
>>   14 |  1130 |     | 481.831396537
>>   15 |  1116 |     | 470.256648783
>>   16 |  1117 |     | 262.774003918
>>   17 |  2907 |     | 73.1337200735
>>   18 |   765 |     |  172.32970181
>>   19 |     6 |     |             0
>> (20 rows)
>> *Worth Lutz*
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160701/2b64ebe2/attachment.html>
More information about the Pgrouting-users mailing list
