[pgrouting-users] Problem with query
Worth Lutz wal3 at mindspring.com
Fri Jul 1 11:42:48 PDT 2016
On 7/1/2016 1:29 PM, Stephen Woodbridge wrote:
> On 7/1/2016 12:07 PM, Worth Lutz wrote:
>> Hi Steve,
>> That method gives the expected results running in psql on the command
>> line.
> Ahhh! OK, I would go with the results from the commandline. pgAdmin
> has bugs where is does not always display the results in all columns.
This is good to know.  I will keep this in mind. I need to work in a
methodical way to determine what is what. I've been trying this and that
and confused myself now.
I'll set up a test case and see if I can display the problem in a
repeatable manner.
> I'm guessing that if you click one of the blank cells in id2 and copy
> and then paste it somewhere you will likely get a result value. Or is
> you run the query and save the results to a cvs file it will have values.
> If this is the case, then this particular issue not a pgRouting bug,
> but a pgAdmin issue.
> -Steve
>> In pgAdmin, I got the previous results with no values in the id2 column.
>> I can get the missing id2 with SELECT pgr_bdDijkstra(..) on pgAdmin
>> also.
>> Confusion reigns here today!
>> I'll see if I can get a test case put together.
>> *Worth Lutz*
>> On 7/1/2016 11:48 AM, Stephen Woodbridge wrote:
>>> What do you get if you do:
>>> SELECT (pgr_bdDijkstra(...)).*
>>> You should probably write this up as an issue.
>>> -Steve
>>> On 7/1/2016 11:08 AM, Worth Lutz wrote:
>>>> Hi All,
>>>> Can anyone explain the strange results (see below) I'm getting?
>>>> ~$ apt-show-versions postgresql
>>>> postgresql:all/trusty-updates 9.3+154ubuntu1 uptodate
>>>> ~$ apt-show-versions postgis
>>>> postgis:amd64/trusty 2.1.4+dfsg-3~trusty uptodate
>>>> ~$ apt-show-versions postgresql-9.3-pgrouting
>>>> postgresql-9.3-pgrouting:amd64/trusty 2.2.3-release-ppa1~trusty1
>>>> uptodate
>>>> The first query gives me 4 values and the second has the 'id2' value
>>>> empty.
>>>> SELECT
>>>>     pgr_bdDijkstra(
>>>>     'SELECT id_base AS id, source, target, cost_len AS cost, rcost_len
>>>> AS reverse_cost FROM _rt_geom_streets_base',
>>>>     11, 6, TRUE, TRUE
>>>>          pgr_bddijkstra
>>>>  (0,11,2087858,482.722955703)
>>>>  (1,3549,2082803,275.837140233)
>>>>  (2,24976,2086339,272.953707069)
>>>>  (3,20623,2086101,484.096255058)
>>>>  (4,48115,2085508,388.315542378)
>>>>  (5,47218,2084557,480.30350456)
>>>>  (6,8387,2094458,476.8149761)
>>>>  (7,248,2093906,255.35844989)
>>>>  (8,1348,2097029,247.294429215)
>>>>  (9,1536,2090136,339.718631568)
>>>>  (10,6465,2091005,330.978413622)
>>>>  (11,3740,2087980,415.137012292)
>>>>  (12,1504,2095856,375.236169771)
>>>>  (13,1505,2090458,466.482679764)
>>>>  (14,1130,2089855,481.831396537)
>>>>  (15,1116,2089664,470.256648783)
>>>>  (16,1117,2139494,262.774003918)
>>>>  (17,2907,2139496,73.1337200735)
>>>>  (18,765,2131538,172.32970181)
>>>>  (19,6,-1,0)
>>>> (20 rows)
>>>> SELECT *
>>>>   FROM
>>>> pgr_bdDijkstra(
>>>>     11, 6, TRUE, TRUE
>>>>  seq |  id1  | id2 |     cost
>>>>    0 |    11 |     | 482.722955703
>>>>    1 |  3549 |     | 275.837140233
>>>>    2 | 24976 |     | 272.953707069
>>>>    3 | 20623 |     | 484.096255058
>>>>    4 | 48115 |     | 388.315542378
>>>>    5 | 47218 |     |  480.30350456
>>>>    6 |  8387 |     |   476.8149761
>>>>    7 |   248 |     |  255.35844989
>>>>    8 |  1348 |     | 247.294429215
>>>>    9 |  1536 |     | 339.718631568
>>>>   10 |  6465 |     | 330.978413622
>>>>   11 |  3740 |     | 415.137012292
>>>>   12 |  1504 |     | 375.236169771
>>>>   13 |  1505 |     | 466.482679764
>>>>   14 |  1130 |     | 481.831396537
>>>>   15 |  1116 |     | 470.256648783
>>>>   16 |  1117 |     | 262.774003918
>>>>   17 |  2907 |     | 73.1337200735
>>>>   18 |   765 |     |  172.32970181
>>>>   19 |     6 |     |             0
>>>> (20 rows)
>>>> *Worth Lutz*
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>> This email has been checked for viruses by Avast antivirus software.
>>> https://www.avast.com/antivirus
More information about the Pgrouting-users mailing list
