[pgrouting-users] Fixed sequence routing.
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Mar 8 08:27:35 PST 2016
And if you want to combine the edges into a single linestring you can
union the edges together, with the caveat that the total path is not
self intersecting.
In general, we do not imbed functionality into pgRouting that can be
easily done in PostGIS. We have supplied some pgsql utility functions
that are mostly PostGIS stuff where there is a common function that
everyone will need. But mostly try to avoid these.
There are are lots of PostGIS tutorials around the web:
https://www.google.com/search?q=postgis+tutorial&ie=utf-8&oe=utf-8
That will get you started if you need some help in this area.
Best regards,
-Steve
On 3/8/2016 10:40 AM, Andrea Nardelli wrote:
> Hello,
> you can just do a JOIN on the edge id between the Dijkstra result and
> the edge table:
> SELECT seq, path_seq, node, edge, d.cost, agg_cost, the_geom
> FROM (SELECT * FROM pgr_dijkstra(
> 'SELECT id, source, target, cost, reverse_cost FROM edge_table',
> 2, 3
> )) as d, edge_table
> WHERE d.edge=edge_table.id
> ~Andrea
> 2016-03-08 15:59 GMT+01:00 Omar Fernando Pessôa <omar.pessoa at gmail.com
> <mailto:omar.pessoa at gmail.com>>:
> Hi guys, sorry about question...
> Does have some of pgrouting functions thats returns linestring
> dijkstra from sequenced nodes?
> for all itens on sequency
> accum linestring from dijkstra item, item+1
> Thanks.
> *Omar Fernando Pessôa*
> http://www.opessoa.info
> Desenvolvedor de sistemas
> Programador C++
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
More information about the Pgrouting-users
