[pgrouting-users] best/fastest way to calculate thousands of trsp routes
McDonaldR
McDonaldR at angus.gov.uk
Mon Apr 24 01:55:08 PDT 2017
Thanks Steve
The function to get the source and target points on to the nearest edges gives a much better result than using nearest node. Now I just need to work out how to get the geometry of the route from these projected points.
Thanks very much for the help
Ross
-----Original Message-----
From: Pgrouting-users [mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: 20 April 2017 16:50
To: pgrouting-users at lists.osgeo.org
Subject: Re: [pgrouting-users] best/fastest way to calculate thousands of trsp routes
On 4/20/2017 6:49 AM, McDonaldR wrote:
> Hi List,
> I’m running pgRouting 2.1 with PostGIS 2.2.2 on PostgreSQL 9.2.20.
> I have 16,000 pupils going to 57 schools. I have a network with turn
> restrictions. I have a function (below) that loops through all the
> pupils and calculates a TRSP route and updates the pupil table with
> the route cost. I have some questions too.
> 1.It’s going to take ~ 2 hours to process all the pupils. Will it
> make things faster if I created, say, 4 functions that each processed
> a different set of pupils? I have a multicore server and memory to spare.
> I have to run this for time and distance and also for all the pupils
> assigned an “optimally located” school. What’s the best/fastest way to
> do this?
Yes, this sounds reasonable.
> 2.I pre-processed the pupil data to assign each pupil the nearest node
> on the network. Some pupils in rural areas are a mile from the nearest
> node and are assigned the node at the end furthest from the school.
> How would I use the pgr_trsp with edges and edge position to create a
> position for each pupil at a point on the nearest edge?
Here is a function that might be useful, or you might modify it for your specific needs. tol is maximum search distance in degrees, you can estimate this degrees = meters/111120.0. It returns the edge_id, pos on the that edge and these can be used to args to trsp.
-Steve W
create or replace function pointToEdgePos(edge_table text, lon float8, lat float8, tol float8, OUT edge_id integer, OUT pos float8)
returns record as
$body$
-- ASSUMPTIONS
-- * edge_table as columns "gid" and "geom"
-- * edge_able.geom uses srid=4326
declare
rr record;
pct float8;
pnt geometry;
geom geometry;
begin
-- create a point from lon, lat
pnt := st_setsrid(st_makepoint(lon,lat), 4326);
-- set the error condition
edge_id := null;
pos := -1.0;
-- find the closest edge within tol distance
execute 'select * from ' || _pgr_quote_ident(edge_table) ||
' where st_dwithin(''' || pnt::text ||
'''::geometry, geom, ' || tol || ') order by st_distance(''' || pnt::text || '''::geometry, geom) asc limit 1' into rr;
if rr.geom is not null then
-- deal with MULTILINESTRINGS
geom := rr.geom;
if geometrytype(geom)='MULTILINESTRING' THEN
geom := ST_GeometryN(geom, 1);
end if;
-- project the point onto the linestring
pos := st_line_locate_point(geom, pnt);
edge_id := rr.gid;
end if;
end;
$body$
language plpgsql stable;
> CREATE OR REPLACE FUNCTION public.pupil_journeys()
> RETURNS character varying AS
> $BODY$
> DECLARE
> cur_pupil refcursor;
> v_pid integer;
> v_pnn integer;
> v_snn integer;
> v_cost double precision;
> v_sql varchar(1000);
> BEGIN
> RAISE NOTICE 'Processing pupil journeys...';
> OPEN cur_pupil FOR EXECUTE format('SELECT pupilid, pupil_nn,
> school_nn FROM edn_pupilschoolroute WHERE pupil_NN IS NOT NULL');
> LOOP
> FETCH cur_pupil INTO v_pid, v_pnn, v_snn;
> EXIT WHEN NOT FOUND;
> SELECT SUM(cost) AS v_cost FROM pgr_trsp('
> SELECT ogc_fid AS id,
> source::integer,
> target::integer,
> cost_len::double precision AS cost,
> rcost_len::double precision AS reverse_cost
> FROM hw_roadlink'::text,
> v_pnn, --pupil_nn gets inserted here
> v_snn, --school_nn gets inserted here
> true,
> true,
> 'select to_cost, teid as target_id,
> feid||coalesce('',''||via,'''') as via_path from
> hw_nt_restrictions'::text) INTO v_cost;
> -- insert route cost into pupil data table
> v_sql:='UPDATE edn_pupilschoolroute SET p_dist = ' || v_cost || '
> WHERE pupil_nn = ' || v_pnn || ' AND school_nn = ' || v_snn || ' AND
> pupilid = ' || v_pid;
> EXECUTE v_sql;
> END LOOP;
> RETURN ‘Well, that worked!';
> CLOSE cur_pupil;
> END;
> $BODY$
> LANGUAGE plpgsql VOLATILE
> COST 100;
> Thanks in advance
> Ross
> *Ross McDonald | *GIS Data Coordinator | Angus Council | Angus House,
> Orchardbank Business Park, Sylvie Way, Forfar DD8 1AT*| t: 01307
> 476419*
> This message is strictly confidential. If you have received this in
> error, please inform the sender and remove it from your system. If
> received in error you may not copy, print, forward or use it or any
> attachment in any way. This message is not capable of creating a legal
> contract or a binding representation and does not represent the views
> of Angus Council. Emails may be monitored for security and network
> management reasons.Messages containing inappropriate content may be
> intercepted. Angus Council does not accept any liability for any harm
> that may be caused to the recipient system or data on it by this
> message or any attachment.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
More information about the Pgrouting-users
