[pgrouting-users] PG Routing Question
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Sep 2 06:38:59 PDT 2017
Hi Andrew,
This is a really good question it gets asked every so often. So I will
cc the pgRouting-users list with my response.
The routing algorithm computes the cost to get to each node following
the road network. If the cost is time based then it takes the speed of
the road segments into account. You can't do meaningful interpolation
between points without taking into account the edges. Think about a path
following the letter "S" or "C", interpolation between the end points
does not take into account the path of the letter or in our case the
roads. Also if you pick two arbitrary nodes they may or may not be
connected directly. So interpolation is not going to make sense.
One option might be to examine each edge, and get the values of the
their respective nodes, then interpolate along the edge and add the
interpolated points into a temporary table, then you can union the
original points plus the interpolated points into pgr_pointsAsPolygon()
Another solution that might work for you if you need better resolution
but this would be the same as above and require more work, would be to
take every edge and break it into 4 equal edges and replace the original
edge so that instead of having one edge and 2 node, you now have 4 edges
and 5 nodes. Then you can rebuild the topology and your driving distance
will have a high density of node.
I hope this helps,
-Steve
On 9/1/2017 10:52 AM, Andrew Wooley wrote:
> Stephen
> I attended your workshop at the FOSS4G Boston conference. I really
> enjoyed it and learned a lot. I have been working on some projects
> using it.
> I came across an issue that I was hoping that you could help me. I am
> using the following example function from Regina's workshop:
> SELECT
> 1 As id,
> ST_SetSRID(
> SELECT D.seq AS id, ST_X(V.the_geom) AS x,
> ST_Y(V.the_geom) As y
> FROM
> pgr_drivingDistance(
> $sql$
> SELECT gid As id, source, target, length_m
> AS cost, length_m AS reverse_cost FROM osm_ways
> $sql$,
> (SELECT id FROM osm_ways_vertices_pgr N ORDER
> BY N.the_geom <-> ST_SetSRID(ST_Point(-111.69429,40.28984),4326) LIMIT
> 1),
> 500,
> TRUE
> ) D INNER JOIN
> osm_ways_vertices_pgr V ON D.node = V.id
> 4326
> ) As the_geom
> It is selecting the vertices in the table and the creating the
> polygon. It works well, but I was wondering if there was a strategy
> for interpolating points along the line to make the distance be the
> input distance between vertices even if there isn't a vertex there in
> the table.
> Thanks a lot for your help.
> *Andrew Wooley* | IT Director
> Mountainland Association of Governments
> 40.311,-111.682
> <https://www.google.com/maps/place/40%C2%B018%2741.0%22N+111%C2%B040%2755.0%22W/@40.3112687,-111.68232,19z/data=%214m2%213m1%211s0x0:0x0>
> http://www.mountainland.org
> 801-229-3844
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20170902/4e2b103c/attachment.html>
More information about the Pgrouting-users
