[pgrouting-users] pgr_TSP(): how to avoid the route returning to the start point
tommaso
tommasodb at googlemail.com
Wed Apr 11 05:35:40 PDT 2018
Hello, I'm testing the TSP feature using this example from the
documentation:
SELECT * FROM pgr_TSP(
SELECT * FROM pgr_dijkstraCostMatrix(
'SELECT id, source, target, cost, reverse_cost FROM edge_table',
(SELECT array_agg(id) FROM edge_table_vertices_pgr WHERE id < 14),
directed := false
start_id := 7,
randomize := false
My problem is that the algorithm returns to the start point after visiting
the last one, while in my use case this is not requested.
There is a option to avoid this? Until now I could not find such a option
in the documentation.
Simply ignoring the last segment is not a solution, because in certain
cases the order of the last and second the last points changes if the
route goes back to the first point. So, I cannot predict which one is the
desired last point.
Regards, Tom
More information about the Pgrouting-users
