[pgrouting-users] [postgis-users] PGrouting extension is not available under PostGIS 2.1.9.
Regina Obe
lr at pcorp.us
Wed Feb 7 05:22:30 PST 2018
Pradeep,
pgRouting is a project separate from PostGIS and has a different mailing list. I've cc'd that list.
pgRouting works fine against PostGIS 2.1.9
so I suspect your issue is EDB doesn't carry pgRouting at any rate for your version. You can encourage them to include it in their distributions or you can compile it yourself if you need it.
Check out the pgRouting website - http://pgrouting.org
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Pradeep Kanth G
Sent: Wednesday, February 07, 2018 4:24 AM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: [postgis-users] PGrouting extension is not available under PostGIS 2.1.9.
Dear All,
I have tried PGrouting extension is not available under PostGIS 2.1.9.
So kindly let me know how add those extension on PostGIS 2.1.9.
Regards
Pradeep Kanth
Ext : 3026
From: Pradeep Kanth G [mailto:pgundala at avineonindia.com]
Sent: Tuesday, February 6, 2018 6:11 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Subject: RE: [postgis-users] Database restarting while using ST Functions
Thanks Daniel for your quick response.
Now this query is working fine without any issues on PostGIS 2.1.9.
Once again Thaks.
Regards
Pradeep Kanth
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Daniel Baston
Sent: Tuesday, February 6, 2018 5:46 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Subject: Re: [postgis-users] Database restarting while using ST Functions
Hi Pradeep,
The code fixes weren't ported back to the 2.1 branch. As a workaround, maybe try replacing calls to ST_CollectionHomogenize(x) with ST_CollectionHomogenize(ST_GeomFromEWKB(ST_AsEWKB(x))).
Dan
On Tue, Feb 6, 2018 at 7:08 AM, Pradeep Kanth G <pgundala at avineonindia.com <mailto:pgundala at avineonindia.com> > wrote:
Thanks Daniel,
It is a PostGIS 2.1.9 (EDB 9.5),after upgrading to PostGIS 2.3(EDB 9.5) this issue has been resolved.
However , we are testing EDB Development version 9.5.And there is no compatible with PostGIS 2.3 it will support only 2.1.9. So kindly let me know how to overcome this issue on 2.1.9.
Regards
Pradeep Kanth
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf Of Daniel Baston
Sent: Tuesday, February 6, 2018 5:13 PM
Hi Pradeep,
Try checking the output of "SELECT postgis_full_version()". If you're not at the latest point-release, you should upgrade. There have been memory handling bugs with ST_CollectionHomogenize that could maybe cause the issue you're seeing.
Dan
On Tue, Feb 6, 2018 at 5:59 AM, Pradeep Kanth G <pgundala at avineonindia.com <mailto:pgundala at avineonindia.com> > wrote:
Dear All,
Kindly raise the below issue with EDB.
Observation : Database restarting while using ST Functions.
Issue : Intersecting with two geometries, while using ST_Intersects and ST_CollectionHomogenize functions
Database is restarting automatically.
Example: ST_Intersects(ST_CollectionHomogenize(p.geometry,c.geometry))
Screenshot:
Regards
Pradeep Kanth
Disclaimer | The information contained in this electronic message (including any attachments) is intended for the exclusive use of the addressee(s) and may contain confidential or privileged information.If you have received this in error, please notify the sender immediately and delete the material from your machine. Any action including review, retransmission, dissemination of this email or the attachments present along with the email by persons or entities other than the intended recipient is prohibited.
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180207/3e60a959/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180207/3e60a959/attachment-0001.png>
More information about the Pgrouting-users
