[pgrouting-users] Converting a shape file to a network
Dave Potts mrdapotts at gmail.com
Sun May 20 09:54:51 PDT 2018
Got it sorted, thanks for the help
On 19 May 2018 at 15:47, Vicky Vergara <vicky at georepublic.de> wrote:
> Dave:
> your table "tmp" does only has id and the_geom columns
> On Sat, May 19, 2018 at 6:45 AM, Dave Potts <mrdapotts at gmail.com> wrote:
>> I tried this and got an error message to the effect missing column
>> med_proj=# \d tmp;
>>                                      Table "public.tmp"
>>   Column  |          Type           | Collation | Nullable |
>>  Default
>>  id       | integer                 |           | not null |
>> nextval('tmp_id_seq'::regclass)
>>  the_geom | geometry(Geometry,3857) |           |          |
>> med_proj=# \d tmp_noded;
>>                                      Table "public.tmp_noded"
>>   Default
>> nextval('tmp_noded_id_seq'::regclass)
>>  old_id   | bigint                  |           |          |
>>  sub_id   | bigint                  |           |          |
>>  source   | bigint                  |           |          |
>>  target   | bigint                  |           |          |
>> Invoking this, should put the results in tmp_noded, which according to
>> the above and the manual at https://docs.pgrouting.org/
>> 2.6/en/pgr_nodeNetwork.html has all the right column
>> Doing this
>> med_proj=# select pgr_createTopology('tmp',1);
>> Given an error,  I don't  think there is anything wrong with the
>> functions, it most be my table layout, but according to the
>> documents,everything is correct.
>> NOTICE:  PROCESSING:
>> NOTICE:  pgr_createTopology('tmp', 1, 'the_geom', 'id', 'source',
>> 'target', rows_where := 'true', clean := f)
>> NOTICE:  Performing checks, please wait .....
>> NOTICE:  ----> PGR ERROR in pgr_createTopology: Column source not found
>> HINT:    ----> Check your column name
>> NOTICE:  Unexpected error raise_exception
>>  pgr_createtopology
>>  FAIL
>> any ideas what I am doing wrong ?
>> Dave.
>> On 17 May 2018 at 21:35, Vicky Vergara <vicky at georepublic.de> wrote:
>>> Hi Dave,
>>> Have you tried:
>>> https://docs.pgrouting.org/2.6/en/pgr_nodeNetwork.html
>>> Its has some issues, but does a reasonable work for pgRouting purposes.
>>> Fixing the geometry would be using postGIS
>>> On Thu, May 17, 2018 at 2:47 PM, Dave Potts <mrdapotts at gmail.com> wrote:
>>>> Hi,
>>>> I am trying to convert a shapefile of linestrings into a suitable form
>>>> for pgroute.  The type of issue that I am getting is that from a casual
>>>> look its looks fine, but if you drill down in to the map, you find there
>>>> are some line segments should connect, but they don't due to the way that
>>>> the data was entered.
>>>> Q. Has anybody attempt this type of thing before and what if any
>>>> solutions did they find ?
>>>> Dave.
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>> Georepublic UG (haftungsbeschränkt)
>>> Salzmannstraße 44,
>>> 81739 München, Germany
>>> Vicky Vergara
>>> Operations Research
>>> eMail: vicky at georepublic.de
>>> Web: https://georepublic.info
>>> Tel: +49 (089) 4161 7698-1
>>> Fax: +49 (089) 4161 7698-9
>>> Commercial register: Amtsgericht München, HRB 181428
>>> CEO: Daniel Kastl
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180520/f13d2596/attachment.html>
More information about the Pgrouting-users mailing list
