[pgrouting-users] Build the "right" direction in a network, from a fixed starting point
Vicky Vergara vicky at georepublic.de
Mon May 21 05:40:03 PDT 2018
So I see your data now,
as a table on a mail, and as first glance I "see" that something is wrong,
But I need to reproduce your problem, so I need the data in such a way that
I can copy paste.
So imagine I have a problem and I need you help me finding what is my
problem:
*I have this data:*
CREATE TABLE edge_table (
    id BIGSERIAL,
    dir character varying,
    source BIGINT,
    target BIGINT,
    cost FLOAT,
    reverse_cost FLOAT,
    capacity BIGINT,
    reverse_capacity BIGINT,
    category_id INTEGER,
    reverse_category_id INTEGER,
    x1 FLOAT,
    y1 FLOAT,
    x2 FLOAT,
    y2 FLOAT,
    the_geom geometry);
INSERT INTO edge_table (
    category_id, reverse_category_id,
    cost, reverse_cost,
    capacity, reverse_capacity,
    x1, y1,
    x2, y2) VALUES(3, 1,    1,  1,  80, 130,   2,   0,    2, 1),(3, 2,
  -1,  1,  -1, 100,   2,   1,    3, 1),(2, 1,   -1,  1,  -1, 130,   3,
  1,    4, 1),(2, 4,    1,  1, 100,  50,   2,   1,    2, 2),(1, 4,
1, -1, 130,  -1,   3,   1,    3, 2),(4, 2,    1,  1,  50, 100,   0,
2,    1, 2),(4, 1,    1,  1,  50, 130,   1,   2,    2, 2),(2, 1,    1,
 1, 100, 130,   2,   2,    3, 2),(1, 3,    1,  1, 130,  80,   3,   2,
  4, 2),(1, 4,    1,  1, 130,  50,   2,   2,    2, 3),(1, 2,    1, -1,
130,  -1,   3,   2,    3, 3),(2, 3,    1, -1, 100,  -1,   2,   3,
3, 3),(2, 4,    1, -1, 100,  -1,   3,   3,    4, 3),(3, 1,    1,  1,
80, 130,   2,   3,    2, 4),(3, 4,    1,  1,  80,  50,   4,   2,    4,
3),(3, 3,    1,  1,  80,  80,   4,   1,    4, 2),(1, 2,    1,  1, 130,
100,   0.5, 3.5,  1.999999999999,3.5),(4, 1,    1,  1,  50, 130,
3.5, 2.3,  3.5,4);
UPDATE edge_table SET the_geom =
st_makeline(st_point(x1,y1),st_point(x2,y2)),dir = CASE WHEN (cost>0
AND reverse_cost>0) THEN 'B'   -- both ways
           WHEN (cost>0 AND reverse_cost<0) THEN 'FT'  -- direction of
the LINESSTRING
           WHEN (cost<0 AND reverse_cost>0) THEN 'TF'  -- reverse
direction of the LINESTRING
           ELSE '' END;                                -- unknown
SELECT pgr_createTopology('edge_table',0.001);
*With that data I am getting:*
SELECT * FROM pgr_dijkstra('select id, source, target, cost, reverse_cost
FROM edge_table', 1, 15);
 seq | path_seq | node | edge | cost | agg_cost
(0 rows)
But this image clearly shows there is a path from 1 to 15, what is the
problem?
Please, try to find out what I am doing wrong. (your answer will help see
your current level of understanding of pgRouting)
and send me data that I can copy/paste into a database so that I can
reproduce your problem.
Regards
Vicky
On Sun, May 20, 2018 at 4:43 AM, andy <aborruso at gmail.com> wrote:
> Hi Vicky,
> On Sat, 19 May 2018 at 19:18, Vicky Vergara vicky at georepublic.de
> <http://mailto:vicky@georepublic.de> wrote:
>> I don't see your data, can you put the contents of the data​
>> ​The only similar thing as "data" I have is your interpretation of a
>> table contents​.
>> This is the data:
>> SELECT ogc_fid as id, source, target, st_length(wkb_geometry)
>>                            as "cost" FROM linee;
>> Here the output (I have added the geom)
> id source target cost geom
> 1 1 2 1875.887941 SRID=32632;LINESTRING(526471.864222973
> 5083313.32108108,527988.654493243 5082209.55351351)
> 2 3 1 1551.56248159 SRID=32632;LINESTRING(525738.392871622
> 5081946.07351351,526471.864222973 5083313.32108108)
> 3 1 4 1506.74402482 SRID=32632;LINESTRING(526471.864222973
> 5083313.32108108,527803.506385135 5084018.30810811)
> 4 4 5 1208.08883443 SRID=32632;LINESTRING(527803.506385135
> 5084018.30810811,528985.605844594 5084267.54594595)
> 5 2 6 1447.12212188 SRID=32632;LINESTRING(527988.654493243
> 5082209.55351351,527020.187466217 5081134.27027027)
> And this is an image generated from this data (my starting point is 1).
> [image: immagine.png]
> Thank you very much
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>  in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180521/a1f0915b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180521/a1f0915b/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180521/a1f0915b/attachment-0003.png>
More information about the Pgrouting-users mailing list
