[pgrouting-users] problems with pgr_pointsAsPolygon
Daniel Kastl
daniel at georepublic.de
Thu Oct 11 08:03:52 PDT 2018
Hi Dave,
There was a blog post I wrote long time ago, but after some improvements to
the pgr_pointsAsPolygon function, when it supported a custom value for
"alpha":
https://georepublic.info/en/blog/2017/catchment-area-calculation-with-pgrouting/
I don't remember details anymore, just that I wrote that post and the
result was quite OK.
It seems I got more detailed boundaries, when the alpha value was pretty
small like "0.00001".
Have you tried such a small number?
Best regards,
Daniel
On Wed, Oct 10, 2018 at 1:43 AM Dave Potts <mrdapotts at gmail.com> wrote:
> I have a collection of x,y points and I am trying to draw a bounding
> polygon. I was unhappy with the default returned, so I decided to a play
> with the alpha parameter.
> I get no result and the value 'NOTICE: n = 1'
> printed on the console,
> My sql is
> pgr_pointsAsPolygon('select id,st_x(st_startpoint(the_geom)) as x,
> st_y(st_startpoint(the_geom)) as y from tmp where label=27,5.0);
> select pgr_version() returns psql (10.5 (Ubuntu 10.5-1.pgdg16.04+1))
> The machine is running postgres 10.5-1
> Is there anything wrong with what I am doing? Using an alpha value of 0
> does not generate an error.
> regards
> Dave.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20181012/0ee51299/attachment.html>
More information about the Pgrouting-users
