[pgrouting-users] driving directions/descriptions
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Tue Feb 12 10:25:26 PST 2019
Hi Robert,
The wiki page link represents the current state of driving directions in
pgRouting. As I mentioned the process is straight forward, but the
details are very dependent on a users specific data. I implemented it a
long time ago for a client's specific data schema, OSM and Google only
have to deal with they one data schema, pgRouting allow every user to
have different data schema so it is not likely a "generic" solution will
be easy to find.
So that leaves you with with a couple of options:
1. building a solution specific to your data schema along the lines outlines
2. having someone else build it for you
3. using and existing solution like OSM and loading your data into that
4. not having a solution
Contact me off list if you want to consider some contract help. If you
want to do it yourself, I'm happy to help if you get stuck but read
through wiki link again because that is the model you need to follow.
Best regards,
   -Stephen Woodbridge
On 2/12/2019 4:37 AM, Robert k wrote:
> Hello everybody,
> I wanted to ask if there is a possibility in pgRouting to generate
> routing descriptions?
> I found these links:
> https://gis.stackexchange.com/questions/20117/does-pgrouting-support-turn-by-turn-routing
> There are many dead links in the article.
> https://lists.osgeo.org/pipermail/pgrouting-users/2011-January/000537.html
> Also, I only found this article on the wiki page of PgRouting. The
> entry is from 2014.
> https://github.com/pgRouting/pgrouting/wiki/Driving-Direction-Instructions
> Is there a feature in PgRouting that generates Driving Direction
> Instructions?
> Can you help there?
> Many Thanks
> Robert
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
More information about the Pgrouting-users mailing list
