[pgrouting-users] Make pgrouting
Boris Hikin boris.hikin at gmail.com
Thu Sep 3 07:16:18 PDT 2020
Thank you, I will try it.
On Thu, 3 Sep 2020 at 17:07, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Boris,
> I can't say much about Redhat/CentOS, but I thought there should also be
> packages available on those platforms.
> On Debian/Ubuntu you can add the PostgreSQL maintained repositories and
> always have access to the latest versions.
> I haven't tried, but this might be also the case for CentOS:
> https://www.postgresql.org/download/
> This is just an example, something that showed up early in my search
> results:
> https://centos.pkgs.org/7/postgresql-12-x86_64/pgrouting_12-3.0.0-1.rhel7.x86_64.rpm.html
> It lists required package names. And you can download the SRC package,
> open it and look into the ".spec" file, which may look like this:
> Summary: Routing functionality for PostGIS
> Version: %{pgroutingmajorversion}.0
> Release: 1%{dist}
> License: GPLv2
> Source0: https://github.com/pgRouting/%{sname}/archive/v%{version}.tar.gz
> URL: https://pgrouting.org/
> BuildRequires: gcc-c++
> %if 0%{?rhel} && 0%{?rhel} == 7
> BuildRequires: cmake3
> # EPEL:
> BuildRequires: boost169-devel
> %else
> BuildRequires: cmake => 2.8.8
> BuildRequires: boost-devel >= 1.53
> %endif
> BuildRequires: postgresql%{pgmajorversion}-devel
> BuildRequires: gmp-devel
> Requires: postgis30_%{pgmajorversion} >= %{postgismajorversion}
> .... if you really want to build yourself.
> Hope that helps,
> Daniel
> On Thu, Sep 3, 2020 at 10:41 PM Boris Hikin <boris.hikin at gmail.com> wrote:
>> Thank you for your replay Daniel,
>> Do you think it will be better to install it on debian or ubuntu ?
>> I installing it on centos 7
>> On Thu, 3 Sep 2020 at 16:28, Daniel Kastl <daniel at georepublic.de> wrote:
>>> Hi Boris,
>>> Do you have all build dependencies installed?
>>> https://docs.pgrouting.org/latest/en/pgRouting-installation.html#dependencies
>>> In particular you may be missing the postgresql-server-dev-xx package as
>>> it's named in Debian/Ubuntu.
>>> Looking at your error output it seems like you try to compile pgRouting
>>> 2.4.
>>> There are already much newer versions in the meanwhile, so you may
>>> better try those.
>>> Best regards,
>>> Daniel
>>> On Thu, Sep 3, 2020 at 8:51 PM Boris Hikin <boris.hikin at gmail.com>
>>> wrote:
>>>> Hi i am getting error when i make pgrouting
>>>>  [  0%] Built target ProcessSQLFiles
>>>> [  0%] Built target build-time-sql-directory
>>>> [  1%] Building C object
>>>> src/withPoints/src/CMakeFiles/withPoints.dir/one_to_one_withPoints.c.o
>>>> In file included from /usr/include/pgsql/server/c.h:53:0,
>>>>                  from /usr/include/pgsql/server/postgres.h:47,
>>>>                  from
>>>> /root/pgrouting-2.4.0/src/withPoints/src/./../../common/src/postgres_connection.h:34,
>>>>                  from
>>>> /root/pgrouting-2.4.0/src/withPoints/src/one_to_one_withPoints.c:30:
>>>> /usr/include/pgsql/server/pg_config.h:14:30: fatal error:
>>>> pg_config_x86_64.h: No such file or directory
>>>>  #include "pg_config_x86_64.h"
>>>> compilation terminated.
>>>> make[2]: ***
>>>> [src/withPoints/src/CMakeFiles/withPoints.dir/one_to_one_withPoints.c.o]
>>>> Error 1
>>>> make[1]: *** [src/withPoints/src/CMakeFiles/withPoints.dir/all] Error 2
>>>> make: *** [all] Error 2
>>>> do you know about this error ?
>>>> Thank You
>>>> Boris
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20200903/ceb6e6da/attachment.html>
More information about the Pgrouting-users mailing list
