[pgrouting-users] "invalid memory alloc request size" on large graphs
Phyks
phyks+pgrouting at phyks.me
Sun Jan 22 01:48:59 PST 2023
> I think 1GB is a hard limit in PostgreSQL .
> See for example this note
> https://git.postgresql.org/gitweb/?p=postgresql.git;a=blob;f=src/include/utils/memutils.h;h=21640d62a647d23a4bfd3f12922b615d9cc03e97;hb=HEAD#l31
> and discussed here - https://postgrespro.com/list/thread-id/1549721
Thanks for the git pointer! It seems this is a limit from
[TOAST](https://www.postgresql.org/docs/current/storage-toast.html)
which could be overcome through [Large
objects](https://www.postgresql.org/docs/current/largeobjects.html)?
> Instead of using pgr_createTopology, have you tried using pgr_extractVertices which will eventually replace pgr_createTopology? https://docs.pgrouting.org/latest/en/pgr_extractVertices.html
`pgr_extractVertices` is working perfectly fine for topology creation,
as detailed in https://github.com/pgRouting/pgrouting/discussions/2255.
> In meantime, I think your best bet is to segmentize your data into groups and reconnect them by overlapping node ids.
> For this I'm using this function for breaking apart https://postgis.net/docs/ST_SquareGrid.html
> (alternatively - https://postgis.net/docs/ST_HexagonGrid.html ) or
> (if you have areas - https://postgis.net/docs/ST_Subdivide.html --
> Or some sort of known boundaries like country, city, states, provinces etc.
> -- I'm going to assume your data is in 4326 (you'll need to change size if it's in another special ref)
> I haven't thoroughly tested this so might need changing and you will need to change to accommodate your field names. Note the 2 in the ST_SquareGrid is 2 degrees.
Thanks a lot for the example SQL for computing connected components over
a grid. I was thinking about doing something similar but did not had a
look at it.
Best,
>> -----Original Message-----
>> From: Pgrouting-users [mailto:pgrouting-users-bounces at lists.osgeo.org] On
>> Behalf Of Phyks
>> Sent: Saturday, January 21, 2023 4:13 PM
>> To: pgrouting-users at lists.osgeo.org
>> Subject: Re: [pgrouting-users] "invalid memory alloc request size" on large
>> graphs
>> Hi,
>>> 1.) set the highest "work_mem" for the session and close all other
>>> running programs ..
>>> SET work_mem = '8GB';
>>> SELECT pgr_createTopology( ... )
>>> -- set back for the default value;
>>> SET work_mem = '1GB';
>> Same issue :
>> =# SET work_mem = '8GB';
>> SET
>> =# (SELECT component, node FROM pgr_connectedComponents(
>> 'SELECT id, source, target, cost, cost AS reverse_cost FROM edges'
>> ERREUR: invalid memory alloc request size 1080000000 CONTEXTE : fonction
>> SQL « pgr_connectedcomponents », instruction 1
>>> 2.) Linux: Enable Swap space ( ~ 20GB or 2x of your RAM )
>>> https://www.digitalocean.com/community/tutorials/how-to-add-swap-
>> space
>>> -on-ubuntu-20-04
>>> 3.) optimize table variables storage spaces ( to less space )
>>> - change your bigint variables to integer
>>> for (about 40M edges) an integer [ -2147483648 to +2147483647 ]
>>> should enought
>>> https://www.postgresql.org/docs/current/datatype-numeric.html
>> As far as I understand, `pgr_connectedComponents` as run in the example
>> above should only query the `edges` table. I already have `source` and `target`
>> set as regular `integer` there.
>> I have the impression the malloc is failing for another reason that OOM:
>> 1/ Malloc size should be about 1GB as per the error message. This is far less
>> than my free RAM and seems to be a fixed buffer size somewhere.
>> 2/ I have only 2GB RAM used on my system (hence 10GB free RAM) and do not
>> see any increase of RAM usage between the start of the
>> `pgr_connectedComponents` query and the error output.
>> For these reasons, I do not expect swap / RAM changes to have any effect
>> here, but instead a configuration option in PostgreSQL / pgRouting to allow
>> allocations of more than 1GB?
>> It seems I'm hitting https://postgrespro.com/list/thread-id/1549721
>> which references https://github.com/pgRouting/pgrouting/issues/291 but I
>> don't see much solutions there apart from using bounding boxes (which is
>> easily done for routing, much less for contraction / connected components
>> analysis).
>> Thanks!
>> Phyks
>>> Phyks <phyks+pgrouting at phyks.me> ezt írta (időpont: 2023. jan. 21.,
>>> Szo,
>>> 14:06):
>>>> Hi,
>>>> I'm trying to use pgRouting on a quite large graph (about 40M edges).
>>>> My graph structure is expected to be quite simple and not very
>>>> connected (being mostly a simple tree structure).
>>>> I came across the discussion on speeding up `pgr_createTopology` for
>>>> large networks (
>>>> https://github.com/pgRouting/pgrouting/discussions/2255#discussioncom
>>>> ment-4739376)
>>>> and am trying to put it in practice for my use case. Moving from
>>>> `pgr_createTopology` to `pgr_extractVertices` gives a huge increase
>>>> in processing time and memory requirements.
>>>> However, when trying to run `pgr_*` (`pgr_dijkstra`,
>>>> `pgr_contraction` or `pgr_connectedComponents` for example) on the
>>>> subsequent graph, I am facing a malloc issue : invalid memory alloc request
>> size 1080000000.
>>>> This is easily worked around with `pgr_dijkstra` since routing is
>>>> mainly local and the edges table can easily be filtered with a bounding box.
>>>> This is not as easy for `pgr_contraction` or
>>>> `pgr_connectedComponents` where tiling the computation (through bbox)
>>>> requires some extra post-processing.
>>>> I'm not sure about the units of the `malloc` error message, but it
>>>> seems to me this is about 1GB allocation which should be no issue on
>>>> the machine and setup I am running. For the record, my postgresql is
>>>> having either a basic configuration (out of the box install) or a
>>>> pgtune-d one, same issue in both cases. My machine has a bit more than
>> 10GB of free RAM.
>>>> Would anyone have more insights on this issue which could help me
>>>> better understand and work around it? This is particularly
>>>> frustrating since computations on a quarter of the table (about 10M
>>>> edges) work perfectly fine and in a very reasonable amount of time.
>>>> Thank you in advance,
>>>> Best,
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
