[pgrouting-users] docker build fails for pgRouting version 15-3.3-main
Imre Samu
pella.samu at gmail.com
Mon Jun 5 06:04:52 PDT 2023
> `docker build` fails when `version.txt` is `15-3.3-main`:
Refresh the program by using the "make update" command.
my test:
git clone https://github.com/pgRouting/docker-pgrouting.git
cd docker-pgrouting
# refresh ...
*make update*
# check the changes:
$ git diff 15-3.3-main/Dockerfile
-ENV PGROUTING_GIT_HASH 113aa3b60f60db20ecc00e28b2ef4ae7d5e76219
+ENV PGROUTING_GIT_HASH 6c47f688c7ec219b5251b0020db4bc439ed2421a
# And this is working for me.
$ docker build --pull -t pgrouting/pgrouting:15-3.3-main 15-3.3-main
$ docker images | grep pgrouting/pgrouting
pgrouting/pgrouting 15-3.3-main c047cac9b5fa 6 minutes ago 629MB
Regards,
Imre
Tokura Gou <tokura.gou at gmail.com> ezt írta (időpont: 2023. jún. 5., H,
10:32):
> Hi community,
> I am trying to build the latest stable Docker image of pgRouting, as per
> the README here:
> Error response from daemon: manifest for pgrouting/pgrouting:15-3.3-main
> not found: manifest unknown: manifest unknown
> However, it works fine for other, earlier versions, for example:
> `docker build fails for version 15-3.3-3.4` works fine.
> How can I build and run a Docker image with pgRouting 3.5?
> Thank you.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20230605/b08a8c17/attachment.htm>
More information about the Pgrouting-users
