[postgis-devel] Re: [postgis-users] Performance and memory problems
strk
strk at keybit.net
Fri Dec 5 10:21:27 PST 2003
dblasby wrote:
> So, what is the multi-geometry it's failing on?
Following is the multi-geometry.
Note though: once I made GEOS2POSTGIS print it (GEOSasText) I got no
segfault anymore. If I add a line of code anywere the segfault is back !
I've had similar experiences with postgresql, and it's very frustrating...
What I remember from my previous experiences (they were trumatic so
its not much) is that uninitialized/unallocated memory was being used
and it was randomly available because of postgresql memory pool mechanism.
It would be helpful having a way to tell postgresql to always free
pfree'd memory (like the FORCE_NEW thing for libstdc++). Any hint on this ?
SRID=30001;GEOMETRYCOLLECTION(LINESTRING(709096.216508478 160373.930761042,709128.867292722 160363.047166294),LINESTRING(709128.867292722 160363.047166294,709138.068877372 160339.597966701),LINESTRING(709138.068877372 160339.597966701,709124.612796593 160331.880508607),LINESTRING(709124.612796593 160331.880508607,709081.276301142 160334.94770349),LINESTRING(709081.276301142 160334.94770349,709056.936625615 160327.329187167),POLYGON((709068.269935615 160376.406104325,709069.106463379 160377.393723007,709068.269935615 160376.406104325,709068.269935615 160376.406104325)),POLYGON((709077.883676116 160376.272546198,709096.216508478 160373.930761042,709077.883676116 160376.272546197,709077.883676116 160376.272546198)),POLYGON((709047.624998362 160348.638487995,709046.64668149 160350.87732853,709047.624998362 160348.638487997,709047.624998362 160348.638487995)))
> I dont think this is a recursion problem - it shouldnt be recursing to a
> depth more than 2 (the original multi* and the sub-component it's
> working on).
> It most likely that there's a problem with the collector function or
> that GEOS is giving back garbage.
Consider that removing the pfree() call puts everything back
in a working state.
--strk;
