[postgis-devel] Re: [HACKERS] PG7.4 ordering operator
strk
strk at keybit.net
Thu Nov 20 02:23:09 PST 2003
tgl wrote:
> strk <strk at keybit.net> writes:
> > Testing postgis support in PG7.4 (2003-11-11)
> > I've encountered to this problem:
> > ERROR: could not identify an ordering operator for type geometry
> > Previous PG versions does not show this problem.
> > Any hint on what might be missing ?
> A default btree operator class for type geometry. PG 7.4 no longer
> uses assumptions about operator names to determine sorting/grouping
> behavior. If you have some operators that provide a scalar sort
> ordering on your datatype, then make a btree opclass to show that.
> See
> http://www.postgresql.org/docs/7.4/static/xindex.html#XINDEX-OPCLASS-DEPENDENCIES
> regards, tom lane
Thanks for the answer, I've one more question:
I've provided a default btree operator class but I'm often
going out of memory when using DISTINCT or UNION clauses.
How can I reduce memory usage in these cases ?
Since passed argument are TOASTED, but I use only a small
initial portion if them to make the computation, can I
avoid DETOASTING them and still reach that initial part ?
The information I need is stored at offset 40 from detoasted data
and is 6doubles long. I cannot find TOAST documentation.
thanks.
--strk;
