[postgis-devel] dumper and WKB
strk
strk at keybit.net
Wed Nov 26 09:26:05 PST 2003
NULL geometries handling has been added.
HEXWKB direct parsing has been made optional (define HEXWKB)
Dave, could you please take a look at the HexDecode function
to see what's wrong with it ?
--strk;
strk wrote:
> I've committed latest changes to dumper.
> <ReportStart>
> WKB parsing is disabled by default, to enable
> it set USE_WKB define to 1 (or whatever else).
> *SPEED ISSUE*
> Slowness is mainly due to conversions, currently:
> GEOMETRY->binWKB->hexWKB->bytea->binWKB
> I've tried making my own HexDecoder to reduce this to:
> GEOMETRY->binWKB->hexWKB->binWKB
> but it is failing...
> Best would be to avoid hex encoding as in:
> GEOMETRY->binWKB
> And this was the initial idea.
> Anyway, this would require a double table scan since a BINARY cursor
> would not be adeguate for other data types (for endiannes issues).
> I will implement this, but WKB parsing will not change, so if you can
> give it a try now your tests will not be a waste of time.
> *CORRECTNESS ISSUE*
> As far as I can tell it is working, so we should not have dataloss
> now. Can you test it ?
> *NULL HANDLING*
> There is currently no NULL handling. I have a question here:
> Are EMPTY geometries encoded in WKB, and how ?
> </ReportEnd>
> Thanks for your attention
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
