[postgis-devel] Re: LW_GEOM questions
David Blasby
dblasby at refractions.net
Wed Apr 14 12:04:23 PDT 2004
ralph.mason wrote:
> I am glad to hear that the indexing is working from results it sounds like the bounding boxes will need to be stored. I would expect that both LWGEOM and GEOMETRY should perform about the same until the memory wall is hit (much sooner with GEOMERTY).
I'm going to experiment with this.
1. Use the last remaining bit of the geometry's type to say "there's a
BOX2DFLOAT4" comming up. This is a pretty major change!
2. provide a "addBBOX(lwgeom)" function that will stick one in (defaults
to no).
3. change indexing functions to be aware of the bounding box.
I've noticed that index searches for lwgeoms are very slightly slower
compared to postgis index searches (up to 1ms). This is most likely
because (1) it has to compute the bounding box and the postgis version
already has one available and (2) the actual index tree is somewhat
different between the two.
For queries like:
SELECT * FROM <table> WHERE lwgeom && <geom>;
you will not notice any speed degregation (1ms is too short)! In fact,
you'll probably find its faster because the index and actual tuple data
will come in faster (less disk pages to read).
For queries like:
SELECT ... FROM <table1>,<table2> WHERE table1.lwgeom && table2.lwgeom;
there is a noticable speed degregation:
1,000 rows -- about 300ms (0.3 sec)
10,000 rows -- about 18,000ms (18 secs)
In order to get this going faster, you would first attach the bounding
box to the lwgeoms. (ie. "UPDATE table1 SET lwgeom = addBBOX(lwgeom)").
I'll experiment and see how much it improves performance...
dave
