[postgis-devel] Query causes Postgres to crash
collin collin at socrates.berkeley.edu
Thu Dec 9 10:48:42 PST 2004
Folks, the following query has consistantly caused Postgresql 8.0beta4
to crash (postgis 1.0cvs (10/15/04),geos 2.0.1,proj4.4.9) on a FC3 linux
pc (1GB ram, 160GB HD, dual 750mhz PIII).
UPDATE grid10m SET
lzmin = (SELECT min(lz) from unfilteredpts WHERE lreturn  && the_geom),
lzmax  = (SELECT max(lz) from unfilteredpts WHERE lreturn  && the_geom),
lzavg  = (SELECT avg(lz) from unfilteredpts WHERE lreturn  && the_geom),
lzstddev  = (SELECT stddev(lz) from unfilteredpts WHERE lreturn  &&
the_geom);
grid10m is a set of 11,000 square polygons.  unfilteredpts is as set of
2.5 million points (2 geometry columns lreturn, freturn).
I am trying an explain analyze on a subset (1,700 grid polys & 400,000
pts), but it has been 2 hours and I still do not have a result.
Any thoughts? Thanks,
Collin
NCALM/NCED, UC Berkeley
